06-30-2015, 06:40 PM | #1 |
Rep 1,135
please help me interpret my dyno results (faloff in power above 6k)
-roughly 64k miles -inspection 2 done last summer (~7k ago) -rogue x pipe, cpi headers -frank smith tune -pulleys -really, really hot today in sacramento (ask finnegan!) im not (too) concerned about the (what i perceive to be a) lack of power, more concerned about the power after 6k. any thoughts would be greatly appreciated. Michael edit- granted the operator let off the throttle early but you can clearly see the curve was not going to recover and magically go above 250 whp |
06-30-2015, 06:51 PM | #2 |
///M-fanatic
193
Rep 3,885
I think it very well could've gone up higher still, and the operator should rev all the way up to fuel cut. All in all, I'm not sure why the dynos for this car have been on the lower side, since I recall your car being peppier than mine when they both were NA with slight bolt-ons :/
07-01-2015, 08:02 AM | #4 |
Rep 2,782
AFR still looks ok though. He should run it up to 8k rpm, unless he noticed a significant power loss or other issue at WOT.
07-01-2015, 10:43 AM | #5 |
///M-fanatic
193
Rep 3,885
BTW Mike, what section1 and mufflers are you currently running? Not that I think they're the issue here, but ughh...your car should be making more power
07-01-2015, 03:48 PM | #6 |
Rep 405
Our stock ecus apparently stop fueling at 6500 according to Frank at ttfs.
Edit- seems that was stated above, and you have a tune which would eliminate that |
07-01-2015, 06:13 PM | #7 |
Rep 2,287
You should check out the Dyno thread from the E90 forum, lots of good information from a post started by Axiom.
http://www.e90post.com/forums/showthread.php?t=916863 What car is this? I or SI ? Either case the ECU does not cut fuel at 6500 RPM. Soft limiters start to kick in a bit higher. |
07-04-2015, 11:09 PM | #8 | |
Rep 12,565
