04-05-2015, 05:21 PM | #1 |
Rep 268
VF Installation Help Needed
Hi guys,
I am really getting close to finalizing my VF570 installation but I'm really stuck on hooking up all of the vacuum/boost lines. I am hoping someone with VF experience can help set me straight. I will reach out to VF, but it's the weekend I am installing the VF570 with a Tial 50mm BOV, See attached photo. 1. This normally ties into the stock VF BPV. With the Tial I see no application for it. Cap it off? 2. Do I run a line from this down to the engine to drain any fluid, or something else? 3. This used to plug into the stock air box (elbow), I see no application for it now? 4. I am hooking up a boost gauge in the cabin, I believe I can get a boost reading off of this T? 5. Does this connect to the nipple on the bottom of the Tial (#7), or somewhere else? 6. Not sure what this elbowed nipple is for. 7. I installed the nipple that came with the Tial BOV I ordered from VF. Does this connect to #5? 8. This is a larger nipple, about double the size of #6. Not sure what application there is for this. Thanks to all who can help provide insight. Last edited by torchmedia; 04-05-2015 at 06:06 PM.. |
04-05-2015, 05:58 PM | #2 |
Rep 2,782
Are you installing a Tial bypass or blow off valve? What model?
04-05-2015, 06:06 PM | #3 | |
Rep 2,703
The vacuum source on the back of the intake manifold should be plumbed to the nipple on top of the BPV. Your boost gauge will need the same vacuum source on the back of the IM Hope this helps
04-06-2015, 10:15 AM | #5 |
Rep 2,782
If the VF kit comes with a bypass, then yes, you will need to cap the hose that routes back to the intake.
04-06-2015, 07:49 PM | #6 |
Rep 268
Mike from VF Engineering wrote me back today and answered all of my questions. I will post his response below for anyone who might need this information down the road.
1. This normally ties into the stock VF BPV. With the Tial I see no application for it. Cap it off? Yes, cap it off. 2. Do I run a line from this down to the engine to drain any fluid, or something else? That line connects the intake pipe to the top of the oil pan. It is used to drain any residual oil from the crankcase vent back into the oil pan. 3. This used to plug into the stock air box, I see no application for it now? That line is no longer used. Remove the hard line from the solenoid and cap off the port. 4. I am hooking up a boost gauge in the cabin, I believe I can get a boost reading off of this T? Yes, you can use the T. The T must be installed on the equalizer tube on the throttle bodies. 5. Does this connect to the nipple on the bottom of the Tial (#7), or somewhere else? One end goes on the equalizer tube and the other end goes to the Tial valve. 6. Not sure what this elbowed nipple is for. That is originally used for the helper port on the Greddy valve. You can cap the fitting since you are using the Tial valve. 7. I installed the nipple that came with the Tial BOV I ordered from VF. Not does this connect to #5? One end goes on the equalizer tube and the other end goes to the Tial valve. 8. This is a larger nipple, about double the size of #6. Not sure what application there is for this. The larger 1” fitting is for the idler stabilizer hose. Note: I wasn't referring to the idle stabilizer hose in #8, but I gather from everything else I'm reading that the port beside the stabilize hose needs to be capped off as well. |
04-06-2015, 08:33 PM | #7 |
#dubspec
6328
Rep 5,200
let us know when you turn the key!
04-08-2015, 10:32 PM | #8 |
Rep 268
Key has been turned, and HOLY CRAP I DIDN'T THINK IT WOULD BE THAT LOUD
lol Youtube just doesn't do the VF570 any justice. I'll be buttoning up the bumper, underbody panels etc this week and and take a video after it's all washed down |
