02-28-2017, 02:52 PM | #1123 | |
Rep 2,704
Edit** Trial fitment looks good. Now to decide on finish and connection between brackets and tubing.
Mirko182.00 |
03-01-2017, 06:29 AM | #1124 |
Rep 218
Inspection II, new headlight washer, new drive shaft flex joint, new xenon bulbs.
Car is purring like a kitten, wallet is crying in the corner.
/// LED Lighting /// Pedal Haus M aluminum pedals and heel plate /// BMW logo puddle lights /// CF wrapped console /// LeatherZ MK4 console storage, armrests, door pulls /// ZHP illuminated shift knob /// BMW under seat storage /// Soundplicity III /// Stubby Antenna /// Eventuri Intake /// Tekcarbon CF valve cover /// Stromung exhaust /// Rogue Engineering Transmission Mounts ///3rd brake light blinker
03-01-2017, 10:30 PM | #1125 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Thanks!
03-02-2017, 05:58 AM | #1126 | |
Rep 218
Autohaus Lake Norman. They're in Denver, NC. Great group of folks. The flex joint problem was found when I asked them to check the linkages and rear sway bar. I get a clunk every once and a while on slow turns. No issues found in that department but they noticed the joint issue. They would have found it with a visual inspection anyway. It was kinda obvious...
SaltyNC369.50 |
03-02-2017, 07:19 AM | #1127 |
Rep 870
Thanks, JCF. Glad they found it and got it replaced for you.
Salty
03-03-2017, 10:21 PM | #1128 | |
Rep 516
03-03-2017, 11:45 PM | #1129 | |
Rep 355
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
03-04-2017, 07:11 PM | #1130 |
Rep 218
Yup. Although I'll admit I've never heard it called that before.
kaybat125.50 |
03-05-2017, 04:14 AM | #1131 |
Rep 506
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
Yes, this might help you look at a before and after. |
03-08-2017, 06:45 PM | #1132 |
Rep 506
Custom GTS Wing
Finally got the first parts for our newest project. We are fitting an M4 GTS wing to the coupe. Here is the RKP High Wing Mounts which actually raise the height up from 6" to 11.5", also received the larger side fins to match. The base is only 2.75", so it looks like the angle should not need much work. Can't wait to get the wing delivered and get some pics up when we are finished.
03-09-2017, 05:18 AM | #1133 | |
1621
Rep 4,294
03-09-2017, 05:45 AM | #1134 |
Rep 506
We are going the same route as APR on the base and creating a reinforced mold to level it out attach to the car. It's always nice to get any feedback on previous experiences with problems.
Much appreciated. |
03-11-2017, 05:15 AM | #1135 |
1621
Rep 4,294
Cheers can't wait to see pics. You say "we" a fair bit? Is there more than one owner to the car? How does that work if there is? Who pays for what? And how does it work if you (hopefully don't) damage the car?
03-11-2017, 10:51 AM | #1136 |
Rep 3,004
Bilstein B12 struts/shocks
Eibach Pro-Kit springs BMW ZHP performance control arms OEM front control arm bushings OEM strut guides OEM strut and spring pads
Racerbruce
03-11-2017, 06:46 PM | #1137 | |
Rep 506
Harrison Motorsports www.HarrisonMotorsports.com Carbon Signature https://www.facebook.com/carbonsignature/ Robinson Racing http://www.robinsonracing.net/ Butler Tire http://www.butlertire.com/ |
03-11-2017, 10:22 PM | #1138 | |
1621
Rep 4,294
03-13-2017, 11:45 PM | #1139 |
Daily driver/Weekend mechanic
Rep 48
Drives: '06 Z4 3.0i Roadster
Billstien B8s to replace the Koni Sports, the Bavauto spring compressor; and I'm not sure why, but I also got the Bavauto code reader.
03-14-2017, 12:50 AM | #1140 |
Rep 313
03-20-2017, 08:13 PM | #1141 | |
Rep 2,704
Finished product. Shop effed up on the color of water transfer film. It was free of charge but not sure. May grow on me.
03-20-2017, 08:26 PM | #1142 |
Rep 2,704
Last piece of the puzzle this year.
Full rear end rebuild with poly bushings all around. Sandblasted and powder coated steel bits.
03-21-2017, 01:53 AM | #1143 |
1621
Rep 4,294
03-26-2017, 05:08 PM | #1144 |
Rep 2,704
Thanks Vanne
And a shot of the assembly ready to go back in. Not out of the realm of the DIY'er. I do not have a hoist and only hand tools. Poly bushes are easy to install. Removal of old ones is way easier if subframe is removed. *Edit*. Of course a 3/8 torque wrench is a necessity
