      11-08-2020, 12:36 PM   #23
Jiaim
Jiaim's Avatar
77
Drives: 2007 PY Z4 3.0SI
I only have a stage 1 E85 tune, panel filter , scorpion exhaust.
Sould be rated around 285hp.
      11-09-2020, 08:02 AM   #24
westunion2007
Drives: BMW 335i
is that 285 WHP? or crank HP? I would assume crank haha.
great color btw!
      11-12-2020, 04:13 PM   #25
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
I just had Kassel Performance put together a tune with an EWS delete. As soon as I get it, I will get some real numbers with all the updated mods.
Just got back from testing both tunes, Epic vs Kassel. Results show
PERFORMANCE Tunes and EWS Delete for the N52 MSV70. Performance tune for N52 with 3 stage intake, headers, Dinan throttle body, 93 octane – Expect 248-253WHP +48whp +23wtq! ********
      12-15-2020, 05:54 PM   #26
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Originally Posted by WickedNy View Post
I was under the impression Active headers were designed for the 3 series n52 which slightly differed in design from the 3.0si...any modification involved to get the to bolt up?
I have had no issue with header fitment, there was some slight modification with the mid pipe. The flanges have to be cut and modified to fit the connecting points.
That's great to know.
So finished testing both tunes from Epic and Kassel performance. I have them on separate DME's and the biggest difference is AWS delete, I am also removing traction control all together.
Kassel is a little cheaper but the car runs strong 💪. Now I just need to cut another 100lbs out of the car. We weighed in at 2950 with me in the car and a half a tank of gas. Class allows us to get it down to 2850
wdb4732.00
      12-15-2020, 08:16 PM   #27
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
EWS delete? What does that do for performance? That just allows a DME to run without matching ISN keys with the CAS.
      12-16-2020, 07:19 AM   #28
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Correct, I am going to try and get it to the dyno after the first of the year for a true side by side. I have another test and tune weekend in a few weeks where we are going to pull track data between the two and get a better feel.
