      11-08-2009, 07:09 PM   #1
dinan19
Drives: AW 2007 335I
Will this wheel setup fit?
I have an 03 z4 2.5i and I want to know if 19x8.5 in the front and 19x10 in the rear will fit? the wheels are Miro 366's and you can see them on **********s.com. I have seen them on a car on here but the guy hasnt got back to me yet and I heard someone say they might not?
AW 2007 335i, JB4, AR dp's, ER CP, HKS SSQ, FMIC, DCI's, Full borla exhaust, ECS boost gauge, varrstoen ES7 19x9.5, 19x10.5, H&R sports
      11-08-2009, 08:43 PM   #2
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
by fit i assume you mean that it wont rub. it all depends on the offset of the wheels. 19x8.5 with a 40mm offset fit the front with no rubbing on mine with 235/30 tires. i have 19x9.5 in the rear with 45mm offset with no rubbing as well (265/35). im also lowered on eibachs.
this should give you some idea, but it all depends on the offset of the wheels
      11-08-2009, 08:49 PM   #3
dinan19
hmm thats interesting. well the wheels are on **********s.com and the offset choice is 35mm do youthink 19x10 with a 35mm offset will fit and not rub on the inside of the strut or stick out the side of the fender?
      11-08-2009, 08:50 PM   #4
dinan19
oh and I meant in the rear lol.
      11-08-2009, 09:02 PM   #5
OH FO SHO
OH FO SHO's Avatar
15
Drives: z4
check PM
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers
-*MY PICTURE THREAD*-
      11-08-2009, 09:02 PM   #6
nickpapa
nickpapa's Avatar
23
Drives: Z4 3.0
yeah 35mm with a 10" width would more than likely rub the outside fender on a non-m. my 9.5 with 45mm offset is pretty darn close to the edge of the fender
