      07-08-2019, 12:01 AM   #375
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
And because Gonzalis is s freaking genius, and summit racing/timken have their catalog fucked up. HM89449 is actually HM89448 <--- have to Re-order this one the CORRECT ONE IS : HM89448
Diff gasket 33108305033 $7
And
Drive Shaft seal 33121213949 $40
And this bit
https://rover.ebay.com/rover/0/0/0?mpre ... 4021332617
Powered by
      07-14-2019, 11:21 PM   #376
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Because the front wheel bearing are being replaced, this will be installed at the same time.
Powered by
      07-15-2019, 12:34 AM   #377
eggman51
Drives: 2006 BMW Z4 M Roadster
moar info!
Is that custom made? I need ducting as well, I think a forum member is making something, but options are good
Vanne1620.50
      07-15-2019, 05:33 AM   #378
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Originally Posted by eggman51 View Post
moar info!
Lol it's the cheapest kit I could find on eBay. It's for the ford Mustang, but will require a few tap welds and some basic modification. My whole front is changing, so this will be the best time to do it. Custom mount for the oil cooler, so this will nicely slot in.
Powered by
      08-18-2019, 04:18 AM   #379
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
_-----_------------____---------------------------------
Car stripped!!! Most bits and pieces sold!! Getting ready for the new build.
Lots of stuff needs to be done before that though.
Powered by
      08-18-2019, 04:22 AM   #380
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Diff kit arrived..
And box of rebuild goodies.
Powered by
wdb4732.00
      09-04-2019, 11:16 PM   #381
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
And while in there, doing the complete drive shaft overhaul.
That's these part numbers
26117841003
26112226527
26122282495
The new OEM CV joint is rather pricey..
Couldent pass this up.
Steeler2428.50
      09-06-2019, 12:50 PM   #382
F360C
Drives: E86 S54
Diff kit arrived..
What ratio did you end up going with? Also are you rebuilding the diff clutch packs?
07 Z4 M Coupe AW/IR
      09-06-2019, 09:22 PM   #383
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
4.10 ofcourse and yep rebuilding the packs. The box with the plates is in the picture where it says invoice. Lol
      09-09-2019, 04:34 PM   #384
vt100
vt100's Avatar
126
Drives: '06 Z4MC, '12 128i
Diff kit arrived..
Sorry to say this! .. but is it dented?
      09-09-2019, 10:09 PM   #385
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
its not part of the bearing race section, so has no consequence. They are manufacturer marks. the other side has a matching one. Thanks for checking it out and pointing it out
Powered by
      10-13-2019, 01:29 PM   #386
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
XX--------------------------------------------------------------------------------------------------------------XX
So things have been developing a bit lately, most predominantly the box arrived.
A bunch more parts in the box.
Cage progress has been good. Car looks like a bombs exploded in it, but that's only due to work in progress.
Powered by
3GFX722.50
      10-13-2019, 03:30 PM   #387
wdb
dances with roads
wdb's Avatar
4732
Wow a complete makeover!
Can't figure out that gauge, did it come by boat or is it supposed to have liquid in it...
      10-13-2019, 05:06 PM   #388
Steeler
Steeler's Avatar
2429
You gonna run E85 Vanne?
Vanne1620.50
      10-14-2019, 03:20 AM   #389
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
AFirm sir. That's fuel that you can see in there. Works on same principle as old Piper airplanes fuel px gauges.
Hope this pic explains it. It's /actual/ pressure. You can have this or install a transducer and put a gauge in the cockpit, but I figure there are enough gauges in there as it is, that I already forget to scan.
The e85 option is there for when I return to Oz.
wdb4732.00
3GFX722.50
      10-15-2019, 08:05 AM   #390
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
nearly done...
Powered by
3GFX722.50
      10-17-2019, 07:54 AM   #391
F360C
Drives: E86 S54
nearly done...
This whole project really excites me! The cage is coming along very nicely.
07 Z4 M Coupe AW/IR
longress104.50
      10-18-2019, 12:55 AM   #392
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Cage finished, just needs wire brush and primer/paint.
Car finally home.
Powered by
wdb4732.00
      10-26-2019, 07:59 AM   #393
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Just bought these. 2nd last bits that I need.
Can't frikking wait!!!
wdb4732.00
      10-26-2019, 09:23 AM   #394
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Awesome! Now the fun part, painting the cage...
With that cage in place, you can remove that rear strut bar. It does nothing and is just weight along for the ride...
Also, note that those control arms put a different load path on the FCAB mount. When BMW Motorsport used that design, they reinforced the mount area. People have reported ripping the FCAB out of the frame with the AKG arms of similar design.
Vanne1620.50
Steeler2428.50
wdb4732.00
      10-29-2019, 11:47 AM   #395
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thanks Micheal,
Ill re-enforce the Fcab mount before running the car. hopefully the bracket trhats welded to the frame is very sturdy. I just a few days ago, just quickly prepped and primed the cage, my painting skills are not good enough to do that justic and will be done at the same time as the WB kit. The shit parts about the whole thing is that my current season is well on the way and i am missing out..
Estimating that this is going to take at least another 2 months before its ready.. Just trying to find the time/cash to do the build justice is very difficult. Esp when you have little kids running around begging to be played with.
All in good time.
Powered by
      11-07-2019, 07:26 AM   #396
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
So I am currently on holidays from the frikkin slavers.. awesome time to start work on the car.
Really loving working on this squirrel. Such a nice way to relax and get a bit grounded.
Took a day to strip the car from panels. (Figure one side at a time is s good start.) Then started matching up panels..
Result after today, pretty good.
This kit fits really well. Surprisingly well actually.
And then the FedEx guy rocked up..
Gotta love working on the car...seriously loving it. So nice to relax, though i am pretty rooted after today. I am pretty sure the missus wished i dropped the car off and get this done by a shop, but i know they will just fuck the kit up, and i want it done right.
so cant wait.. tomottow start stripping the other side...
Powered by
wdb4732.00
