BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > e92 335i front? clunks/rattle
Reply
      05-06-2016, 12:21 PM   #1
Beisofmarko
Finland
20
Drives: e92 335i
Hey, I drive 2006 (07 model) e92 335i MT.
Recently i've started to get this rattling/clunk/popping noise
that seems to come from front and right side.
Its best heard when driving slow 10-40 km/h.
Time between clunks/pops dont increase if i increase speed.
I went to solid asphalt parking lot and kept driving around 30km/h straight and
i kept hearing popping sounds from right front side, when i turned wheel all the way and started make a circle, the popping noise became somewhat louder??
I looked underneath my car today and checked all bolts behind the wheel that they are tight and if there's loose on anypart but everything seemed normal
and all connections were tight??
Only wierd thing is that when i took the belly pan off, i found 1x 13mm nut standing ontop of that?
It's exactly same as the 3 nuts that hold topside of strut/shock at enginebay side, but they all were there allready. So could this
be related to this? couldnt find spot where this is missing..
Anyway, This is really frustrating as its really annoying and i'm on somewhat
of a budget and therefore don't wanna replace everything as buying new parts blind.
Sorry for bad english and all help is appreciated!!
      05-08-2016, 02:09 AM   #2
BashShah
Drives: 2012 335i Sedan
So is the popping still there after the bolt was removed from the belly pan?
You have to figure out if it is wheel rotation based or rpm based?
Best regards,
Reply
