BMW 3-Series (E90 E92) Forum
Coolant problems
04-22-2016, 09:45 PM | #1 |
Rep 1,362
Coolant problems
So I have a 335d m-sport that I bought brand new!
Since I bought it I installed a electronic performance wheel which gives me coolant temp reading! It never went more than 86 F Since 2-3 months, I see temperature going up to 98F And it happens on different type of driving, when the car idles and on the highway at 120 km/h I dunno what to do! I'm still under warranty and the dealers said that nothing is wrong ( no check engine) I use to hear the the fan start. Now I never hear them, I tried to let the car idle and let the temperature go up to 98F and I still cannot hear the fan start! I told the dealer to check it and they said ( 2 dealerships) that everything was normal! Could it be a bad thermostat or a temp sensor ? I'm confused!! Dealer doesn't want to do anything??? |
04-23-2016, 06:03 AM | #3 |
Rep 52
I have the same exact car as you with 85k miles. About a month ago i discovered the cooling fan wasnt kicking on. Dealer tested the fan and sure enough it was dead. Swapped for a new one (pretty quick fix) and all is good now. Check if your cooling fan is on when you turn on the ac. If its reasonably warm outside the ac should also kick on the cooling fan.
04-23-2016, 08:52 AM | #4 | |
Rep 3,557
Has your cooling system been disturbed during maintenance ? It might possibly have air in the system. |
04-23-2016, 10:48 AM | #5 |
Rep 109
Are you sure those temps are F? Would be pretty typical if C.
There is a way to get the dash to show coolant temp by getting into secret menu; do a search. You can then check the steering wheel readout. |
04-23-2016, 12:01 PM | #6 | |
Rep 1,362
Fan never starts even tho dealership tested it and told me they were fine! The temperature is not normal, I've had the car since new and it never went over 86 degree Now it's at 98 |
04-24-2016, 03:35 PM | #8 |
Rep 3,557
Logan, cars that have all emissions in place can do this. If you're in middle of DPF regen when you turn car off, fan runs after shutdown to relieve high temps under the hood.
04-24-2016, 07:33 PM | #10 | |
Rep 1,362
Coolant
At 70 mph my temp can go up or down 81-98 |
04-24-2016, 09:16 PM | #11 |
Rep 3,557
You shouldn't need radiator fan help when on freeway. I'm sort of wondering if this is another harmonic balance. That would cause water pump to not run.
335dM, any funny things going on with power steering or alternator intermittently ? |
04-25-2016, 06:21 AM | #12 | |
Rep 1,362
I'm kind of leaning towards a bad temp. Sensor |
04-25-2016, 05:03 PM | #14 | |
Rep 1,362
04-27-2016, 11:08 AM | #15 |
Rep 215
Drives: E39 M5, F15 35d
OP, are the temps you're seeing measured in F or C? If C, you're OK, those are within spec. If F, they're far below where they should be and your thermostat is likely broken. Please confirm whether F or C, then see here for thermostat info: http://www.e90post.com/forums/showth...ghlight=thermo
04-27-2016, 02:36 PM | #17 |
Rep 336
Drives: 2010 BMW 335d
Garage List 1984 Dodge Ramcharg ... [0.00]
1988 Ford Bronco 351 [0.00] 2002 BMW e39 540i S ... [0.00] 2010 BMW 335d [0.00] 1997 Husaberg FC600 [0.00] 2010 X5 35d [0.00] 2015 Can-Am Outland ... [0.00] 2004 Ford F350 Supe ... [0.00] 2014 Ford Edge (Com ... [0.00] 2014 John Deere D130 [0.00] 2010 John Deere JS46 [0.00] |
04-27-2016, 03:23 PM | #18 | |
Rep 3,557
04-27-2016, 04:47 PM | #19 |
Rep 109
98C is just a couple of degrees higher than what I see with some frequency (205F or 96C). During regens I get to 100C or very close.
I replaced my thermostat in the fall of last year due to temps being too cold as Cuda suggests below. |
04-28-2016, 07:43 AM | #20 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
I believe that these thermostats are designed to fail open, so typical symptom would engine never gets to normal operating temp 86-88C
Have you ever had any part of the cooling system replaced like EGR cooler, etc? |
04-28-2016, 02:40 PM | #21 | |
Rep 1,362
That's it I'll just change the temp sensor even if I'm under warranty and change coolant. F&$ing stealership! I'm pissed at them not to do anything about it! |
04-28-2016, 02:53 PM | #22 |
Rep 1,623
Have you confirmed coolant temp from something other than your steering wheel? I assume theres a discrepancy with your wheel and not your actual coolant temp.
If your fan does kick on, its reaching the HI speed fan temp on the fan switch. That means the coolant in your radiator is hot enough to activate it, which again, leads me to believe your temps are fine. Thermostats do fail in the open position, which will cause issue getting to operating temp but, your fans are kicking on... I'm sure the dealer would like nothing more than to charge you hundreds of dollars to replace your thermostat or even replace unnecessary parts, the fact they tested and told you everything is working, again, leads me to believe there's an issue with your wheel and not the actual coolant temp. Confirm coolant temp another way before you start throwing parts at it. |
