      10-08-2010, 03:57 AM   #1
alphagamma
alphagamma's Avatar
26
Drives: 2002 WRX, 2011 1-series M
Buying a used 2007 BMW M Coupe
Sorry if this thread has been done before. I've searched and found the stuff the in the FAQ: http://www.zpost.com/forums/showthread.php?t=377102
this thread: http://forums.bimmerforums.com/forum....php?t=1375143
Aside from the following:
  • Motor Mount Bolt Issue
  • Rear sway bar mounts
  • Loose strut-to-firewire braces
  • Sporadic windshield wiper motors
  • Ejector units stuck
  • Different paint shades or color of panels from frame (indicate car accident)
  • Broken or cracked windshield wiper stalkers
  • Window switches
  • Window operation
Is there any other issues known among the Z4 M Coupes that I should know and check for?
      10-08-2010, 07:51 AM   #2
r4gs
Viper Driver
Singapore
36
Drives: F-16
^that is comprehensive indeed. i'm not even familiar with 'ejector units stuck', which is referring to what may i ask?
perhaps u can also cross check, at least for interlagos blue metallic, that the factory paint does NOT in fact cover 100% of the front side fenders. you WILL notice the portion where the fenders are fastened to the frame a 'line' of blue over what appears to be black primer. this is normal and consistent afaik for interlagos blue. i do know that alpine white is the complete opposite, where u SHOULD expect the side fenders to be 100% painted.
also, make sure the central locking system functions as there have been a couple of examples where the actuators fail to properly unlock the car. u will also want to ascertain the correct amount of oil (5.5 liters) is in the engine as these are often overfilled, be it at dealerships or otherwise.
      10-08-2010, 07:56 AM   #3
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
That's a terrible thing to be stuck. You'd think they would have redundant explosive charges for when the first one didn't eject you. When I need to bail at 155 mph, I need to bail. Obviously, there are explosive bolts on the roof as well. They've seen Top Gun and they don't want to repeat what happened to Goose.
      10-08-2010, 08:11 AM   #4
RBull
Drives: 2007 M Coupe
^LOL
      10-08-2010, 11:21 AM   #5
boydgti
boydgti's Avatar
Drives: 2007 z4m
Make sure it had the 1st service check done, critical
      10-08-2010, 11:23 AM   #6
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
You pretty much hit it on things to look for. An 07 should still be under warranty so you have that going for you.
      10-08-2010, 12:13 PM   #7
Swashplate
Swashplate's Avatar
Drives: in Anger.
Don't forget broken cupholders. I have seen alot of that.
Side Note- What happened to Goose is impossible. End Rant.
Side Side Note - That film is still Bad Ass !!!
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs
1217/1815
!!! BOILER UP !!!
      10-08-2010, 12:29 PM   #8
Swashplate
Swashplate's Avatar
Drives: in Anger.
We should make a checklist form for prospective buyers. That might be rather useful....hmm did I just volunteer ...
1217/1815
!!! BOILER UP !!!
      10-08-2010, 10:29 PM   #9
r4gs
Viper Driver
Singapore
36
Drives: F-16
^on the topic of ejection seats, i strap myself into one almost daily and it's always at the back of ur mind. fact being, if i ever need to use that $800,000 rocket seat, it had better damn well not do a 'goose' on me!
      10-08-2010, 10:46 PM   #10
johanness
Drives: 2008 Z4MC
Our cupholders SUCK!
      10-08-2010, 10:47 PM   #11
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
The first jet I flew actually had det cord in the canopy to shatter it. I didn't know if I should be more nervous about the rocket engine under my butt or the det cord exploding in my face.
      10-08-2010, 10:58 PM   #12
r4gs
Viper Driver
Singapore
36
Drives: F-16
^that's the canopy fracturing system - cfs. had a friend of mine who had the cfs activate on the ground while closing the canopy. he has permanent superficial scars all across both arms, as the blast tore right through the flight suit material. it was that substantial. does make me feel uneasy if i ever have to use the system, but it does work as advertised?
      10-08-2010, 11:14 PM   #13
pokeybritches
2006 BMW Z4M  [8.50]
I knew a few people that had their visors up when they punched out (takeoff at sunset, land at night). Lead in their eyes, scars all over their faces. Better than becoming a smoking hole I guess. That was back in Kingsville, not too far from you. All I can say is I was happy when I moved up to a twin-engined jet that wouldn't go down from a birdstrike. LOX instead of OBOGS, no det cord, twin engines =
OP - you'll also want to feel around the edges of each of the body panels. If they are rough the car may have been repainted following an accident.
