02-22-2008, 02:40 PM | #45 |
Rep 1,210
Most people that have that problem go with the concealed display its about 1/2 the size of the V1 face and can be easily hidden in the dash, ashtray, etc.
02-22-2008, 08:34 PM | #46 |
Rep 4,365
Concealed display is extra I take it? I'll do some more research Thanks.
02-22-2008, 10:58 PM | #49 |
Rep 1,210
Sorry I missed that. You want to use the rear view wiring harness. It will be towards the back of the dome light housing. It's prewired for a universal garage door opener even if you dont have one which is why it has a power wire in it. To get to it you can take a flat head and open up the base of the mirror assembly (clam shell I think is what people call it) inside you'll find the plug and the wiring harness. I remember not being able to unplug it so I just reached into the opening, located my wire (probably wrapped) and spliced it without unplugging the wiring harness. Let me know if this helps.
02-24-2008, 12:12 AM | #50 |
More than you can afford pal....ferrari
181
Rep 1,471
im just going ot use the space i have up in the map light assembly. going to be a PITA but will be worth it. also i will be tapping the purple wire with white stripe like the OP. wish me luck. thanks zealot. ill let you know how it works.
02-24-2008, 01:29 AM | #51 |
Rep 1,210
Ya thats what I ended up using cause unplugging it wasn't possible for me, I'm sure it's doable though. Also have a list of wires handy when you do it because your carry might vary slightly. Or if you have a voltmeter that would be your best bet to test which wires get power when the key is on slot 2 and dont when its not.
02-26-2008, 09:43 AM | #52 | |
Rep 821
03-14-2008, 07:21 PM | #55 | |
1821
Rep 5,337
BMW wires are COLOR CODED. Lavender wires are live with 12V power at switch position 1. The strip color determines the amount it is fused. The minimum fuse is 5AMP. No strip means un-fused power (danger! Do not tap!). Green wires are live with 12V Power at switch position 2. There are a couple of other color wires I have yet to figure out what the color stands for, but they all supply power in a specific fashion. For example, the wire that I tapped for the UGDO installation (see thread here: http://forums.bimmerforums.com/forum...highlight=UGDO) supplies DIMMED power (meaning it dims with the headlight dial, same as the stereo on the dash) is grey with red stripe. I haven't dug in the back of the stereo to see if the grey wires are indeed dimmed power when headlight is switched on. I've dug into the E9X overhead console and the color scheme is identical. Lavender = switched 12V at 1, green is switched power at 2. |
03-17-2008, 10:48 AM | #57 |
Rep 274
Drives: 2010 128i Conv.
Check on bimmerfest - search V1 hardwire
03-20-2008, 01:02 PM | #58 |
Rep 2,412
Drives: E30 M3 Cecotto, F85, G05, G07,
I have V1, but I don't have the hardwire kit, which kit on the V1 website is the one I need for a hardwire? Or could I just go to Radioshack?
03-20-2008, 01:42 PM | #59 |
Rep 4,365
Man, you really need to read the threads before posting
03-21-2008, 12:31 AM | #60 |
Bean2GO
18
Rep 330
According to the National Conference of State Legislatures, radar detectors are banned in all vehicles in the state of Virginia and the District of Columbia, Washington D.C. Radar Detectors are also banned in big trucks in the states of New York and Illinois. Plus, under federal law, the use of radar or laser speed detectors is illegal in all commercial vehicles over 10,000 pounds. However, radar detectors are allowed in all noncommercial vehicles in all other states.
03-27-2008, 05:32 PM | #61 |
Rep 598
so i finally ordered my V1 and received it today. i am soconfused as to even how to take down the dome light. ughhhhh...this sucks. i just want my V1 in the car! it doesn't even work in the ashtray power supply.
Once I get the dome light fixture down i am pretty sure I can figure it out. |
03-27-2008, 08:56 PM | #62 |
Rep 1,210
You just use a small flat head screw driver wrapped in a towel and pry it out from the front towards the back, or maybe back towards the front one of them has hinges one has springs.
03-27-2008, 10:41 PM | #64 | |
Rep 4,365
03-28-2008, 09:27 AM | #66 |
Rep 2,120
can all who have installed a V1 PLEASE post pics of what it looks like in a Z4,
to date I have never seen a picture of one in a Z4 and I want to see how far it sticks out Roadster really, but even a coupe would do!
Imola Red Roadster |
