08-08-2011, 12:59 PM | #1 |
baby chicken eater
46
Rep 424
Drives: 07 E90 335i - 08 3.0si coupe
Quick Question for a new Z owner
so i was thinking i could put my Miro 942's on my Non "M" Coupe but wanted to guidance from some Z experienced owners. the offsets seem pretty close and doable.
Details Miro 942's (Replica 313's) The rim sizes are 19x8.5 front with 235 35 tires and 19x9.5 rear with 265 30 tires. The offsets are 35 front and 33 rear. thank you for your guidance. |
08-08-2011, 01:50 PM | #2 |
Rep 409
the fronts will rub unless you add neg camber or go to a 225/35 tread
the rears will stick out from the fender line unless you add neg camber. if you lower the car, neg camber will automatically be added, but you will need an alignment to adjust the differences in toe.
Last edited by v3.0si; 08-08-2011 at 03:51 PM.. Reason: spell-check you nincumpoop! |
08-09-2011, 08:29 AM | #3 | |
baby chicken eater
46
Rep 424
