      06-12-2011, 01:38 PM   #1
sho-one
MMA fighter and F1 test driver
Drives: Z4///M coupe bulletproof
Apex 18x9.5" et35 sq setup
Hey guys, I know you prob heard this before, but what do you think of:
1) 18x9.5" et35 255 vs 18x9.5" et35 265 all around for the z4M?
2) Does anyone have any experience with this setup?
3) Is a spacer definitely needed and or camber or will I be fine with stock suspension?
4) Does this look weird from the front of the car?
Thanks again for all your help.
NOW:08 M.Coupe SMB #102/248 #1669/1815
:|MORRVS8|APEX8|SS.X-pipe|SS.PW.Loop|AFE.intake|Matte.grill|short.ant|Z HP.knob|interior.LED|bulletproof
09 Audi Q5
THEN:96Accord|98Camry|04TSX SC|06 M3|06A4|05Civic Si|05Imprezza|05S2000|08FJ
      06-12-2011, 04:11 PM   #2
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
Shereef_Osman was running the 9.5" Apex squared setup with 265s for a while.
The fronts won't fit with stock suspension/camber without rubbing.
And you'd need a serious amount of camber up front+spacer to prevent rubbing especially with a 265 tire.
Check this thread under the "Squared Setup" section for other possibilities.
http://www.zpost.com/forums/showthre...highlight=apex
The coupe in the picture is running 9.5" with 265 tires.
      06-12-2011, 07:00 PM   #3
sho-one
thanks dude, damn I wish they made the 9" or 8.5" wheel more concave, it's prob the only reason I don't go with the normal setup.
09 Audi Q5
      06-12-2011, 08:33 PM   #4
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
I definitely feel for you, i was in the same boat as you a few months back and wanted concave fronts as well. I ended up going with 9" fronts and 10" rears, the most aggressive you can go on on stock suspension/camber.
      06-12-2011, 10:16 PM   #5
sho-one
thanks dude, so how are the 9" rims in person? Does the difference in concavity between the fronts and the rears bother ya?
09 Audi Q5
      06-27-2011, 10:43 PM   #6
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
445
Drives: E30 M3, F10 M5
Here is an 18x8.5" next to an 18x10"
The 8.5's have about an 1" of concavity for the spokes before the large drop down into the lug area
