      08-22-2011, 01:16 PM   #1
suprtran
suprtran's Avatar
111
Drives: BMWs
Will these rims fit a Z4M?
Dimensions are:
19 x 8.5 front et 32
19 x 9.5 rear et 25
Car is lowered with coilovers. Thanks.
      08-22-2011, 04:23 PM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
fronts might need a veeeery minor fender roll, if you have no negative camber. also depends if you go wider than 245F and 275R wide tires
there are smarter people here, but I'm probably right
      08-22-2011, 10:43 PM   #3
Endless619
DHS
Endless619's Avatar
Originally Posted by suprtran View Post
Dimensions are:
19 x 9.5 rear et 25
They should fit fine no issues. I was lowered with an 18x9 +22 (with 235 tire) and didnt rub and am on 19x8.5 +35 (245 tire) with over a 2 inch front drop and no rubbing issues. Check your camber as well.
2023 BMW M4
2016 X3
