05-23-2011, 11:59 AM | #1 |
Rep 2,232
Drives: Made in Bavaria
Z4M wheels options? TPMS needed?
Hi guys. Picked up a new 2006 Z4M this weekend with 32k on the odometer and am looking at changing out the factory 18" wheels and had few questions.
1) My car has a TPMS button but when I press it I get nothing. No light. No indication in the dash so does this mean its not working OR that I don't have TPMS mounted in the factory wheels? Confusing as I am coming from an e92 M3 which I sold which had a more ah graphic representation of TPMS status! LOL 2) Am looking at aftermarket wheels possibly 19x8.5 ET35 Front and 19x9.5 ET22 Rear for the car. Will this set up work? Do I need to buy new TPMS sensors (if the current wheels don't have them - see above) and if so which ones work? Am looking at Tire Rack for a number of possibilities and understand they will mount sensors, tires, and wheels for shipment together at a unit cost. Has anybody mounted anything larger like 20" wheels, is this an option? 3) Car has a set of 18" Pilot Sport A/S already mounted on it but not sure for how long and look to have some tread left but less than 1/2 so what is the average tread span life? If I am upgrading to 19" then this would be a better option to order wheels/tires together. 4)What do folks use for winter tires if any? Don't get snow currently in Texas where I am stationed but have a set of 18" wheels and snow tires from my M3 which I may keep if they'd fit and work for snow duty so is keeping them for that role vs selling them a better option? Thanks Md
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten '15 BMW M3 (Black/Black) - gone not forgotten '10 BMW X5M (Black/Black) - gone not forgotten '08 BMW M3 (Space Gray/Black) - gone not forgotten |
05-23-2011, 12:25 PM | #2 |
704
Take a look at this post for #2. Cars built after Oct 06 (read post for details) have TPMS built into the wheels; those before use another method.
TPMS will show an error in the instrument cluster when the warning is active. Otherwise there is no indicator. I don't believe pushing it when the warning isn't active is going to show you a thing; then again I don't go pushing it much except to clear an error or after adding air. Car isn't with me, or I'd go look. Every now and then mine loses synch with the monitoring system and I have to press the TPMS to clear the error light (after I check the tire pressures of course). Some of these questions are probably answered in the manual. Here are few places to find it if yours didn't come with one--I don't have a lot of the details memorized so I find myself referring to it from time to time. Link |
05-23-2011, 08:19 PM | #3 |
Viper Driver
36
Rep 1,311
1) the easiest way to tell if u have tpms is to look at ur valvestems. rubber valvestems = flat tire monitor, metal valvestems = tpms. if u have either system, pressing and holding the corresponding button on the center console above the ashtray will recalibrate the system and produce a amber tire-looking light on the dashboard. after approximately 5-10 seconds of driving, the amber light should extinguish indicating the system has recalibrated itself for ur current tire pressures. i use 32psi front and 30psi rear to dial out some understeer for ur reference.
2) those wheel widths and offsets will fit perfectly flush with the fenders and zero rub whatsoever with the recommended tire sizes (235/35, 265/30). note that with 19's, u will have a more noticeable wheel gap and a small difference in overall tire diameter, which mildly affects speedometer readout. 20's will also fit if u so choose. 3) all-seasons should last about double that of summer tires, so expect another 15,000 to 20,000 miles with half the original tread depth remaining. 4) where are u stationed in texas? granted i experience no snow and lowest temps of about the teens yet run just fine with the stock oem summer continentals. |
05-23-2011, 08:56 PM | #4 |
Rep 10,309
Drives: A///MERICAN!!!
I was under the impression all Z4M got TPMS but could be wrong. If you don't have TPMS installed on a car that should have it, or are having a TPMS error, there will be a light illuminated on your dash like the 3rd one down in the pic of my dash (I took mine out, just adds weight, makes wheels harder to balance, and I can live with the light). Other than that, there's no problem with running w/o sensors, provided you remain conscious of your tire pressure, which I hope you do anyway
05-23-2011, 09:00 PM | #5 |
Rep 11,667
It was a model year change for '07+
'06 uses the ABS system to monitor. '07+ uses in tire TPMS IIRC this was due to a gov reg change
05-23-2011, 09:05 PM | #6 |
Rep 10,309
05-24-2011, 06:48 AM | #7 |
M = Midlife Crisis
65
Rep 2,006
I believe it was a Cars built in the U.S. Regulatory change. All 2006's have TPWS.
http://www.bmw.co.uk/bmwuk/bmwcorpor...tml?selPage=10
2006 Z4MC - #LL93158
05-24-2011, 07:20 AM | #8 | |
Rep 527
05-30-2011, 12:17 AM | #9 |
Rep 2,232
Checked. Have rubber stems. No TPMS in wheels. Pressed button and held and sensor light light up then went out as described above. Thanks for info.
06-13-2011, 03:25 AM | #10 |
DHS
205
Rep 4,011
I have an 08 and don't have them on my aftermarket wheels. Just puts up a light on your dash. A quick piece of black tape gets rid of the light. It won't hurt anything if you run with them out. My M3 has the older sensor, not on the actual wheels.
Also, 06 models had the other sensors not on the actual wheel.
2023 BMW M4 2016 X3 |
06-13-2011, 04:46 AM | #11 |
Rep 2,138
Drives: Me
On the 'older' cars, it really is not a 'other type' of sensor. It is the computer(s) monitoring each wheel for rotational speed. When the rotational speed on a wheel changes by a certain delta with regard to what the actual speed is, the car assumes low tire pressure and lights the light.
I can dig out the BMW speak tonight from the WDS. |
07-04-2011, 10:42 PM | #12 | |
Rep 308
08-11-2011, 12:59 PM | #13 | |
Rep 116
Even though I considered 19" wheels, I just bought a set of BBS CH Black 18" wheels and tires from Tire Rack for my 2007 Z4 ///M Coupe: - front 8.5" 35mm - rear 10.0" 40mm (required 18mm spacers and longer bolts) IMO, I feel 18" is the best compromise of looks, comfort, handling & cost. Also paid $200 for the flat tire sensors to be installed @ Tire Rack. I installed them last night and I am very happy with them. I have the same set (18” BBS CH), but silver, on my 2007 Z4 Coupe 3.0si, that I am selling.
Currently own: - Z4 ///M Coupe with Black BBS CH-wheels
Previously owned: - Z4 Coupe 3.0si, Z3 ///M Coupe S54, Z3 ///M Coupe S52, ///M6, 635csi, 533i, 323i, F25 X3 with ///M Sports Package |
