01-10-2016, 02:23 PM | #1 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Suggestions on getting cables loose
I recently purchased an Intravee II from a fellow member of the forum. I have a 2006 Z4M Roadster. Using this video as a guide (same car as mine), I pulled back my carpet enough to see the amp, and the pass-through area, and I can see the 6-pin audio cable with the white pairs of wires. The problem is, I can't figure out how to get to the end of it. It feels like it must be trapped somewhere or behind something. I also feel some other cables around the pass-through, but I can't seem to get to the ends of those, either.
For those that have done one of these installs, can you offer any helpful tips? Any magic to freeing the ends of the cables? I'm so close, yet so far away from having this done. Thanks! Salty
01-13-2016, 09:34 AM | #2 |
Rep 218
Are you saying you can see the wire that is in the loom with all the others or the actual "loose" end of the connector? Pull back more of the carpet to give you better line of sight. Unless they are already plugged into something you should be able to jiggle them loose from whatever they might be stuck on. You might also try going at it from the passenger side pass through at the subwoofer. Perhaps they're fed into that area already?
/// LED Lighting /// Pedal Haus M aluminum pedals and heel plate /// BMW logo puddle lights /// CF wrapped console /// LeatherZ MK4 console storage, armrests, door pulls /// ZHP illuminated shift knob /// BMW under seat storage /// Soundplicity III /// Stubby Antenna /// Eventuri Intake /// Tekcarbon CF valve cover /// Stromung exhaust /// Rogue Engineering Transmission Mounts ///3rd brake light blinker
01-13-2016, 08:11 PM | #3 | |
Rep 870
I'll tackle it again soon. Thanks for the hints. I hope you're doing well. It looks like winter finally arrived here in the Carolinas. I'm ready for those 70 degree winter days again, so I can drop the top. That was phenomenal. See ya! Salty
01-14-2016, 11:25 AM | #4 |
Rep 218
That's very odd. They're usually just dangling.
01-27-2016, 10:11 AM | #5 |
Rep 1,107
If you haven't been able to get to it by feel I think you'll have to free up some more of the rear fabric/cover. If I recall, I think mine was wedged under the plastic cubby.
01-27-2016, 07:15 PM | #6 | |
Rep 870
Were you able to push on the plastic from behind in the trunk/boot or did you have to go in from the front tray. I know how to take all that out, but I'd rather not. :-) Thanks! Salty
01-27-2016, 09:33 PM | #8 | |
Rep 870
Salty
