06-18-2008, 03:01 PM | #45 | |||
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
Well I spent at least 3hrs staring at my engine to determine if it was fully behind the front axles and I concluded that maybe 58% of the engine is behind the front axles. So yes there is such thing as a FMR layout but by the strictest of definitions the Z4 is NOT one. Sorry guys.
"when the engine is in front of the driver, but fully behind the front axle line, the layout is sometimes called Front Mid engine Rear FMR layout instead of the less-specific term front-engine." Quote:
06-24-2008, 12:10 PM | #46 | |
Rep 238
06-24-2008, 12:49 PM | #47 |
Rep 4,144
Why the pi$$ing contest over the definition of mid-engine? That's not the real point.
What is important is overall weight and it's distribution. Distribution is not just front-back 50-50. It includes how far out the weight is from the CG, i.e. the moments of inertia. If all the weight is out in the front and back then the car has a higher polar moment of inertia (inertia about the vertical axis). What you want is smaller polar moment of inertia so that the car turns easier. This is done by putting as much weight as close to the center of gravity as possible. You also want the CG to be lower to the ground to help keep the body from rolling in turns. Traditionally, you could get smaller polar moments of inertia by sticking the engine right behind the driver but ahead of the rear axle. That is what is most people think of when they think mid-engine. Whether this is technically correct or not doesn't matter. It's weight distribution that matters, not where the engine is located. Having said that, I don't know what the moments of inertia are for either the Z4 or Boxter/Cayman. My guess is that they are close with the P cars maybe a little better. I don't know where to get these numbers. If you are doing mods, then when you add weight try to add it close to the CG. If you're taking weight off it is better to take it off of the ends of the car, mostly front and back. I wish it were simpler but unfortunately, there's not too many things you can do to noticeably affect weight distribution. Generally I think the best first performance mod -- for both handling and acceleration -- is to change the wheels and tires. Make them lighter (that rotating mass thing again) with stickier tires. After that I'd work on brakes. You don't have to replace them altogether, though some of the after-market BBKs have some rotational weight savings. But a pad and fluid change would make them better for hard use. A strut brace is cheap so I might consider that too. But the best investment as mentioned above is in the driver. BMW CCA has events where you can get time behind the wheel with an instructor. Just getting out on the track for one day can improve your skill. Not only that but it's fun. First time, casual experiences with these cars makes it seem like the Porsche's are better. But looking deeper, when an experienced driver takes these cars out it's the BMW that gets the nod.
2017 F80 YMB.
06-24-2008, 01:00 PM | #48 |
Rep 282
Drives: '15 M235 & '95 M3 tracktoy ;
It's difficult to make a genuine (such as it is) front mid engine car with a long engine like an I6 or V12, at least not with anything approaching current day style sensibilities. A V6 or V8 makes it possible, even if it means stuffing some of it under the windshield. The Corvette probably fits the definition, or is close, and as was mentioned sometime earlier, some of the Mazda RX's with their shorty engine did as well.
06-24-2008, 02:06 PM | #49 | |
Rep 238
06-24-2008, 07:26 PM | #50 | |
My favorite sign.
169
Rep 4,333
06-25-2008, 02:43 PM | #51 |
Rep 4,144
I guess that's useful for stiffness. But the idea is if moment of inertia is lower then less turning force (torque) is needed. If more of the mass is closer to the CG then it's easier to turn than if the mass is farther from the CG. Nothing complicated. But I believe that is one of the main reasons for using a mid-engine design.
2017 F80 YMB.
