06-26-2017, 09:44 PM | #1 |
Rep 2
Driver's Door Pull Handle
Hello All -
I have a 2003 Z4 and I am am having an issue with the driver's side door. To be honest I am not even sure that is what the part is called that I am having trouble with. I have tried searching and have only come up with issues people are having with the actual latch mechanism. On my car (as seen below) the lower portion of the pull handle separated away from the door itself. Is this a problem I can fix myself and if so what part(s) do I need. Also, I'd be curious if there is some type of tutorial as I am not incredibly car savvy. Thank you all for any assistance you could offer! |
06-27-2017, 06:43 AM | #2 |
Rep 2,697
Get familiar with realoem. It is your best source of info that I have found. http://www.realoem.com/bmw/enUS/show...diagId=51_4912
To address your question, push on the silver cover (part 12) from the top and it will slide of the handle (item 11). It may take a bit of effort if it is the first time off. You can access the screw inside the handle once the cover is off. Hopefully the screw receiver in the door arm pad is not dinked.
Tags |
2003, door, handle |
