06-23-2017, 06:18 PM | #1 |
Rep 6
2006 Z4M Roadster Advice (Purchasing)
Hi
I am looking at a z4M Roadster with 155,000 Kms (96,000 Miles). Things that i know to look out for: Convertible top motor goes bad due to water Engine Needs to do Rod Bearings Engine needs Vanos maintenance Is there anything else i should look out for ? Thanks |
06-23-2017, 09:15 PM | #2 | |
Rep 6
06-24-2017, 10:54 AM | #3 |
Rep 4,057
I have a regular Z4 and I love it but I gotta say - don't be too hasty! Why not wait for some of the many M owners here to comment before you decide.
06-24-2017, 11:05 AM | #4 |
Rep 754
Woah Woah Woah, don't jump out too quick. I was the same way because I was considering an e46 M3 but I purchased a Z4M with over 80k miles on it. I've put on 8k miles which have consisted of countless canyon runs, two track days, and daily high speed driving. If you know how to DIY then maintenance is cheap. There are so many forums on basically everything. That being said, this car needs maintenance! You have to change the oil, fluids, and valve adjustments but that's just part of owning/taking car of any car... and for an oil change I bought the Castrol 10w-60 TWS oil with a filter for $60 on amazon, shits cheap. Vanos and Rod bearings are capable of blowing up at any time, that's just part of owning the car. Keep the car healthy.
06-24-2017, 03:09 PM | #5 |
Rep 6
haha okay i guess i will keep it in mind. With my budget im getting the lower end of the z4m. With actually a little less money i could be in the top range for regular z4s.
Here is what is available to me. 2007 Bmw z4 3.0 50,000km 20k Cad 2005 Bmw z4 3.0 80,000km 15k Cad 2006 Bmw z4m Roadster 155,000km 22k Cad |
06-24-2017, 05:45 PM | #7 |
Rep 4,057
For the two Z4s, note that in 2006 the cars had a midlife upgrade. If the 2007 is an si, it will be almost as quick as the M but only to 50 - 60 mph when the M will pull away. The 2007 will have an aluminum and magnesium engine making it light for handling, but it can't take additional stress from power upgrades. And there's not much available anyway. If that is what you are after then go for the 2005. And also let's see what others think of that M.
06-25-2017, 01:10 AM | #8 | |
Rep 72
2014 328i M Sport Melbourne Red
2012 X5 35i 2004 Z4 30i 2001 323i 2008 Wrangler Unlimited Rubicon |
06-25-2017, 10:16 AM | #10 |
Rep 2,546
If you're worried about the higher maintenance cost of an ///M, don't forget the reduced MPG. If it's anything more than just a weekend car, the cost of maintenance will be nothing compared to the extra cost of fuel. Hell, a 505hp 7.0 liter 2007 Corvette gets better mileage than an ///M. Sad to see a higher hp 7.0L American V8 in a heavier car get better mpg than a German 3.2L in a lighter car.
06-25-2017, 12:13 PM | #11 |
Rep 10,662
There's a lot of doom out there about these cars. Read enough on the internet about anything, and it's doom doom doom. I've owned a Z4M Roadster now for over 6 years with two different cars, and the worst thing that has happened is the driver's side window switch stopped working. I've been having some issues related to a stater/alternator/who the hell knows what for the past couple weeks, but any of those which turn out to be the ultimate culprit will be cheap to fix.
In my experience, the Z4M is the most reliable car I've ever driven/owned. |
kaybat125.50 |
06-25-2017, 01:02 PM | #12 |
Rep 269
I wouldn't say the Z4M is any worse than other performance cars, and/or any other BMW in general. The nice thing I found is that most of the issues are common and well documented so there is good support. Also, there is lots of documentation, tools, etc and a lot of it can be done by yourself if you're handy.
The oil and filters are readily available. 5L in Canada costs about $60. Labor will be labor. I never found the mileage a particular problem, but it has been a weekend/fun car for me. |
06-26-2017, 11:10 AM | #13 |
salty cowboys fan
6158
Rep 3,406
Nothing wrong with the non-M, I quite liked my previous 3.0i. Felt much lighter, which it was (by around 200 lbs IIRC) and better on very tight backroads where power wasn't a big deal. You'll still be paying a decent amount to lovingly maintain any BMW though.
If you can do your own wrenching, maintenance costs go way down. Parts can be a bit pricey on the M (e.g. front rotors $250 each )
she’s home! '22 M4 Comp xDrive
06-26-2017, 12:34 PM | #14 |
Rep 626
Can't speak for high mileage cars (my Z4M has 36k), but maintenance costs are nothing extra over the usual German/performance car costs. Just follow a preventative schedule and you shouldn't see the need for an expensive fix.
That being said, definitely get a pre-purchase inspection done. If possible, do a Blackstone oil analysis and that should put your rod bearing worries at ease. Good Luck! |
06-26-2017, 07:44 PM | #15 |
Rep 165
I had 125k on my '06 ///Mr when she met with an untimely demise last year. I then searched the entire eastern seaboard for another identical roadster. I found one in New Jersey with 32.5k miles for $24k.
the 2 major issues I had with the first one was that the radio needed to be replaced and the last year the convertible top stopped working. I assume that was a motor issue but never got around to fixing it. Needless to say I LOVE this car! |
06-29-2017, 01:26 PM | #16 |
Rep 6
Hey guys thanks for the advice. Right now i am looking at the 3.0i. Unless a really desirable z4Mr comes up. My decision is based on that a 3.0i is cheaper, thus leaving me money on the side to do all the bushings and suspension and fluids.
I am thinking i am going to do maintenance work like ECS's: cooling refresh kit https://www.ecstuning.com/b-assemble...117573751lv2a/ front suspension rebuild kit level 2 https://www.ecstuning.com/b-meyle-pa...e463112-2~kt2/ rear suspension rebuild kit level 2 https://www.ecstuning.com/b-assemble...326770824kt10/ And then get suspension work done. That should make a the car "new" again. Am i missing anything else i should do? |
06-29-2017, 02:22 PM | #17 | |
Rep 202
2007 Z4M's, especially the red with red interior and lower miles.
2006 Z4 ///M, Interlagos Blue/Beige
