06-22-2017, 05:09 PM | #1 |
Rep 500
Complete Fluid Maintenance
I think I'm going to jump on this one really soon as the PO didn't keep the best records. So why not restart the process. And I just brought her out of hibernation. Just wondering if anyone has posted up anything relating to this all in one place. I didn't see anything but then again as I get close to 50 years old, when I search the forums I often skate right past stuff right in front of my nose.
Here's what's on the list...... for my Z4M roadster. Replace both belts - OEM BMW Brake fluid Clutch fluid Transmission fluid Rear Differential fluid Engine oil Coolant |
06-22-2017, 10:26 PM | #2 | |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Not sure what the clutch fluid is.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
06-22-2017, 10:38 PM | #3 | |
Rep 97
The clutch fluid is the same fluid/reservoir as the brake fluid. You just bleed the clutch from the bottom of the car. |
06-22-2017, 10:47 PM | #4 |
Rep 97
-Transmission fluid : OEM BMW 75w90 MTF-LT3 (buy 2 liters fill till pours)
-Differential fluid : OEM is pricy $160, but I've been using Liqui-Moly Fully Synthetic Limited Slip Differential Fluid 75W140 (buy 2 liter fill till pours) It works amazing, for half the price. -Brake fluid : OEM recommended unless you plan on tracking it (buy 2-3 bottles to flush out entire brake system and clutch) -Coolant : OEM recommended of course -Engine oil : 10w60 Castrol or BMW brand (shell) w/oem filter EcsTuning.com has all these products at great prices! All in stock too. Should cost you around $300-350 for all the fluids (recommend changing the diff (2)/trans (2)/oil pan plugs too) |
06-23-2017, 09:53 AM | #5 |
Rep 1,031
Would you guys recommend "Royal Purple 01512 Synchromax High Performance Synthetic Manual Transmission Fluid" as a substitute?
08 M Coupe Ceramic Black Fabspeed Headers MCS 1WNR Poly FCAB Stoptech BBK Vibra-Tech Epic Tune Apex EC7 RPI Scoop Eventuri Stromung Rogue X Pipe Varis Diffuser CF E92 GTS Wing CF Roof
06-23-2017, 10:41 AM | #6 |
Rep 528
Drives: E86 Z4MC; E92 M3
That's what I have in my coupe and I love it. Big difference over the OE fluid (that's in my roadie) in terms of feel, especially with the 1-2 shift.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
06-23-2017, 10:52 AM | #7 | |
salty cowboys fan
6158
Rep 3,406
Would NOT recommend Royal's MaxGear oil in the diff though. It says on the bottle it has FM added, but it was groaning like a mother. Switched back to redline 75w140 and she's quiet again
shes home! '22 M4 Comp xDrive
06-23-2017, 12:10 PM | #8 |
Rep 528
I've heard the same thing about this on the E46 M3 side, quite a bit of complaints about the RP Diff Oil making noises. Redline seems to be quite popular on the E46 side as well.
06-23-2017, 12:57 PM | #9 |
Rep 1,107
+1 for Royal Purple Synchromax in the tranny. I've got over 30K miles experience with it (just changed at 60K last fall) and it has been great. Smooth shifts even in sub-freezing temps.
06-23-2017, 03:05 PM | #10 |
Rep 758
Sometimes with an LSD when you switch formulas the friction modifiers in the new fluid have to displace the friction modifiers from the old formula that have saturated the LSD clutch discs. The LSD can be quite noisy until this happens and it may take some time (multiple hundred miles) to get a complete change of FM in the LSD clutches. You have to really have faith the new lube is worth it to have the patience to wait it out....
Top Down 365
06-28-2017, 10:26 AM | #11 |
Rep 500
Stole this from the "other" thread link noted above.......
2006-08 Z4 M Roadster / Coupe Engine Oil Volume : 5.5 litres Suggest Interval : Recommended : Castrol TWS Motorsport SAE 10w-60 Synthetic Castrol Formula RS 10w-50 Synthetic Liquimoly SAE 10W60 Synthetic Race Tech GT1 Parts : Engine Oil Filter BMW PN # 11 42 7 833 769 Engine Oil Filter O-ring PN # 11 42 1 741 000 Oil Pan Plug PN # 07 11 9 904 550 Oil Pan Plug Washer PN # 07 11 9 963 151 Transmission Oil Volume : 1.5 litres Suggested Interval : Recommended : Catrol MTF-LT-2 PN # 83 22 0 309 031 Options : Amsoil 5w30 Manual Syncromesh Amsoil 75w90 MTF 1/2 Redline D4ATF & 1/2 Redline 75w140NS Gear Lube. Royal Purple Pentosin MTF2 Parts : Screw Plug with Gasket Ring PN # 23 11 7 531 356 Differential Oil Volume : 1.1litres Suggested Interval : Recommended : Castrol SAF-XJ PN # 83 22 1 467 993 Castrol SAF-XJ + FM PN # 83 22 2 282 583 Options : Amsoil Severe Gear 75W140 Redline 75W140 GL-5 Gear Oil Parts : Notes : Find a parking lot and do several tight circles in both directions to aid lubing. Brake Fluid Volume : 1 litre Suggested Interval : Power Steering Fluid Volume : Suggested Interval : Coolant Volume : 10.7 litres Suggest Interval : Instructions for Oil/Inspection Reset Insert Key Hold Trip Reset Button and turn ignition to first position Hold Trip Reset Button until display shows "Inspection Reset/Oil Change Reset" Release and Hold Trip Reset Button until Reset flashes Release and Press Trip Reset Button once Release and Press Trip Reset Button again Next oil service interval will be shown and disappear Oil service lamp is now reset |
