      02-09-2016, 08:59 AM   #1
SD ///M4
///Multiple
SD ///M4's Avatar
Cup holder screws
Does anybody know the part number for the third screw that attaches the vent to the plastic post on the cup holder mechanism? Is it the same as the two screws that hold the vent to the dash?
My cup holder is broken and when I took it out I noticed that the plastic post was broken and the screw is gone.
While I'm at it, does anyone know the part number for the little plastic cap that fits over the top screw by the vent?
Thanks!
P.S. I tried searching...
P.P.S. I have the Ultimate Cup Holder, I just want to fix the stock one.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
      02-09-2016, 09:22 AM   #2
SD ///M4
///Multiple
SD ///M4's Avatar
Ok, after a little more searching it appears that the part number for the screw might be 65758235255 and the description is "Torx screw for plastic material". This is from realoem.com.
In searching for this part number on this forum I saw references to removing two Torx screws to remove the cupholder, but my screws are black Phillips head screws.
      02-09-2016, 03:00 PM   #3
Clearancediver
Drives: 2004 Z4
Just replaced my drivers side air vent... Philips head screw for mine as well.
Sent from my smart phone...
      02-13-2016, 06:29 AM   #4
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Button cap is found here. Not sure what color you have. Buy some spares as BMW will probably drop production in a year or two.
My cup holder was secured only with Phillips screws.
      02-13-2016, 12:17 PM   #5
SD ///M4
///Multiple
SD ///M4's Avatar
Thanks! Looks like both getbmwparts.com and ECS Tuning have them in stock. Definitely going to order some spares!
