02-04-2016, 01:40 AM | #1 |
Mechanical Engineer
96
Rep 1,025
Possible Alternator Issue
I recently started seeing a strange electrical issue, that I suspect is a failing voltage regulator in my alternator. I read this thread
http://www.zpost.com/forums/showthre...=669131&page=2 I have the occasional flashing of warning lights, as well as the stereo/nav restarting. I've been logging the voltage through torque/obdii reader, and here is my question. The voltage I see from the alternator seems to fluctuate a lot, but never shows the extreme spikes that others have reported. The dips down to around 12V happen just after the RPMs drop when I take my foot of the accelerator. Here are a couple screen shots of the voltage log. What do you guys think? Alternator or battery? |
02-04-2016, 08:43 AM | #5 |
Rep 233
Alternator is suspect assuming all your connections are clean and tight and your belt isn't slipping. Voltage shouldn't dip below 13v with the engine running.
02-04-2016, 11:39 AM | #6 |
Mechanical Engineer
96
Rep 1,025
Battery is around 2.5 years old, but its the really small Deka one. I figure the battery is probably on its last legs also, but I've had a dead battery before and never seen it do this. Also, if there is a problem with the alternator, I want to make sure its fixed before I install another battery.
02-04-2016, 03:58 PM | #7 |
Mechanical Engineer
96
Rep 1,025
02-04-2016, 04:37 PM | #8 |
636
Rep 3,124
That's about what my voltage looked like before I got a limp mode, TPS, and Throttle Actuator codes.
Was my battery. When my alternator went it failed hard with no warning. Voltage was a 45° downward slope.
02-04-2016, 05:10 PM | #9 |
Mechanical Engineer
96
Rep 1,025
When your alternator failed, did it go quick enough to avoid killing the battery as well? My primary concern at the moment with replacing the battery is that I'm overlooking an alternator problem and it will end up trashing the new battery.
02-04-2016, 06:56 PM | #10 |
636
Rep 3,124
I noticed the car was idling kind of funny on my way to work.
About 10 miles into the trip, while at a stop light, I punched up Volts on DashCommand and I was at 11.7 V. I revved the engine to see if it would go up, because sometimes when the regulator goes you can still get charging at higher RPMs, but it went down, so regulator was completely dead. Then and only just then did the yellow batt indicator come on on the dash. I cut all unnecessary loads and high tailed back home. Was at about 10.7 V when I got home. Battery was about 2 year old H6 AGM, and seemed to survive.
02-04-2016, 07:57 PM | #11 | |
Mechanical Engineer
96
Rep 1,025
02-04-2016, 09:23 PM | #12 |
Rep 233
Your alternator can provide the car with all the current needed to run the car. The battery's job is to operate the starter and to stabilize voltage not supplement the alternator or do its job. I can't imagine that this is not a bad alternator. Not saying your battery might not be damaged now as well as the car may be trying unsuccessfully to run off the battery.
02-05-2016, 04:14 AM | #13 | |
Rep 880
The 2 "pins" sticking out on the top of this regulator are coals/carbon and they get worn thus the generator/alternator can't produce enough current. Maybe it's a bad translation on my part, English is not my native language after all. The coals/carbon are replacable, though I usually change the entire regulator since it's so cheap anyway. |
02-05-2016, 03:35 PM | #14 |
636
Rep 3,124
^ Brushes!
Do alternators have brushes? I thought that was just generators. I don't think I've ever taken an alternator apart, so I may be wrong.
02-05-2016, 05:28 PM | #15 | |
Rep 880
Edit: After some Googling it seems like the part used in a car is called alternator in English. It converts mechanical movement into AC and it is converted in the diode bridge to DC. A generator converts mechanical movement into DC straight away. Seems like it's only the Alternator that have "brushes". |
02-05-2016, 11:59 PM | #16 |
636
Rep 3,124
Exactly.
The brushes are part of the "commutator" which does the same job as the diode bridge, but mechanically with parts that wear out. Low loss, high current silicon diodes became plentiful in the late 60s. Prior to that, the generator was the only good option.
02-06-2016, 01:05 AM | #17 |
Rep 1,917
Mine went recently. The day before I got a couple of flashing lights like ABS, traction etc. Next day they had gone away so I kinda shrugged it off. Then on the way home from work it died in the middle of the highway.
02-08-2016, 01:57 AM | #18 |
Mechanical Engineer
96
Rep 1,025
where did you get a replacement voltage regulator, the link in the thread above shows them as unavailable.
02-08-2016, 02:55 PM | #19 |
636
Rep 3,124
American Engines Co.?
That's where I got mine. Looks like they ran out.
02-09-2016, 02:30 PM | #20 |
Rep 1,917
02-10-2016, 11:34 AM | #22 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Will that work? Salty
