01-31-2016, 11:20 AM | #2 |
Rep 758
Go to this site where the Russian BMW car club hosts the BMW TIS.
http://translate.google.com/translat...m%2F&sandbox=1 Click on Repair Manual Scroll down and click on the E85 link Then scroll down and click on 61. General Electrical Then click on Switches Then click on Replacing Rocker Switch for Side Windows (Side Vod) Then click on Replacing the switch outside rearview mirror (up to 04/2006) You'll be at the instruction for the driver side door. Passenger side (Side Pere) is the same method.
Top Down 365
01-31-2016, 05:26 PM | #3 |
Rep 2,704
You will have to remove the door card which entails removing 4 screws.
2 are hidden behind the slide off door pull, 1 is behind the pop out ABS badge, 1 is hidden behind the pop out cover behind the door release handle. You can now carefully pry the card off the door. Expect to break a few of the push in retainers upon removal. The switch has to be pushed out of the door card from the inside.
