      01-31-2016, 10:43 AM   #1
z4brownderby
Drives: 05 z4 3.0
2005 Window Lift Switch
how to install window lift switch for 2005, Z4 ?
      01-31-2016, 11:20 AM   #2
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Go to this site where the Russian BMW car club hosts the BMW TIS.
http://translate.google.com/translat...m%2F&sandbox=1
Click on Repair Manual
Scroll down and click on the E85 link
Then scroll down and click on 61. General Electrical
Then click on Switches
Then click on Replacing Rocker Switch for Side Windows (Side Vod)
Then click on Replacing the switch outside rearview mirror (up to 04/2006)
You'll be at the instruction for the driver side door. Passenger side (Side Pere) is the same method.
Top Down 365
      01-31-2016, 05:26 PM   #3
Steeler
Steeler's Avatar
2428
You will have to remove the door card which entails removing 4 screws.
2 are hidden behind the slide off door pull, 1 is behind the pop out ABS badge, 1 is hidden behind the pop out cover behind the door release handle.
You can now carefully pry the card off the door. Expect to break a few of the push in retainers upon removal.
The switch has to be pushed out of the door card from the inside.
