01-30-2016, 08:34 AM | #1 |
Why so serious?
141
Rep 743
BMW Z4 ABS sensor question
According to REALOEM, each side has its own part number.
I found a retailer near me that has just the left sensor (I need the right side sensor). They assure me that this sensor can fit on either side. Is this true? Can the sensor be used on either side? I'm confused because, then what would be the point of having two different part numbers... |
01-30-2016, 11:59 AM | #2 | |
Rep 18,727
I looked at realoem and found P/N 34526757281 as the rear ABS sensor. Qty 2 same P/N for either side. I checked, and the front ABS sensors are different right to left: Right is 34526792896, left is 34526792897. The front is probably dictated by the design of the steering knuckle.
01-31-2016, 06:10 AM | #3 | |
Why so serious?
141
Rep 743
