Go Back   ZPOST > Marketplace > Sponsors Classifieds
      05-30-2013, 04:21 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
811
Drives: Independent Tuning Specialists
:: ECS Tuning :: Z4 BMW Performance Big Brake Kit|Back In Stock
Now that your pocket rocket will go from zip to 60 in a flash, have you considered how you're gonna stop it? Would a fresh stock of super stoppers interest you?
Consider the ECS Big Brake Kit. Massive six-piston calipers with pads already loaded; semi-floating rotors; ECS caliper brackets; Exact Fit brake lines, Super Blue brake fluid, and all necessary hardware. Everything you need to install a high performance braking system, delivered in a single box.
Fitment:
BMW Z4 2.5i
BMW Z4 3.0i
BMW Z4 3.0Si
Click HERE to order today!!!
      05-31-2013, 03:12 PM   #2
ECSTuning
ECSTuning's Avatar
811
      06-03-2013, 03:04 PM   #3
ECSTuning
ECSTuning's Avatar
811
      06-06-2013, 09:35 AM   #4
ECSTuning
ECSTuning's Avatar
811
      06-06-2013, 01:30 PM   #5
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
Drives: F87 LBB ///M2
2017 M2  [10.00]
2008 Z4M - SOLD  [0.00]
Does this fit Z4M?
      06-06-2013, 02:42 PM   #6
ECSTuning
ECSTuning's Avatar
811
Originally Posted by R0ME0 View Post
Does this fit Z4M?
This kit is not designed for the Z4M. IF it would fit it would actually be a LBK (little brake kit) as the Z4M comes with 345x28 rotors, while the kit uses 325x25 rotors.
      06-11-2013, 09:50 AM   #7
ECSTuning
ECSTuning's Avatar
811
      06-17-2013, 10:06 PM   #8
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
Will this fit the 3.0si with stock 108 rims?
      06-18-2013, 09:08 AM   #9
ECSTuning
ECSTuning's Avatar
811
We have a fitment template found HERE, which you can print to insure the kit will fit behind your wheels. That being said the 18 inch Style 108 will have enough barrel space to clear the kit, you may run into issues with the back of the faces making contact with the caliper. The contact with the caliper can typically be solved with a 5mm spacer, I would take this as an opportunity to measure your car for spacers and "flush" the wheels out closer to the fenders for a more aggressive look.
      03-25-2015, 12:00 PM   #10
ECSTuning
ECSTuning's Avatar
811
      04-09-2015, 11:23 AM   #11
ECSTuning
ECSTuning's Avatar
811
Click HERE for your E39 i6 ECS 6 Piston Big Brake Kit
      04-13-2015, 12:09 PM   #12
ECSTuning
ECSTuning's Avatar
811
Click HERE for your E82/E88 128i 6-Piston Big Brake Kit
      04-13-2015, 03:01 PM   #13
ECSTuning
ECSTuning's Avatar
811
Click HERE for your E39 540i 6-Piston Big Brake Kit
      04-13-2015, 04:17 PM   #14
ECSTuning
ECSTuning's Avatar
811
Click HERE for your E90/91 325/328/330i/Xi 6-Piston Big Brake Kit
      08-10-2015, 07:02 PM   #15
nemex12
Drives: e60,z4
do you sell the calipers only? thanks
if you want perfection buy a mercedes, or marry an accountant
      08-11-2015, 08:41 AM   #16
ECSTuning
ECSTuning's Avatar
811
The calipers in this kit are BMW part numbers 34116786741 and 34116786742 they can be found HERE on the site.
-James
