      02-24-2012, 05:54 PM   #1
DataStream18
Drives: 2003 ESS TS1 Z4
Oil pressure light
From time to time when I turn the car off the oil pressure light comes on and beeps. I come to a complete stop and the cars revs are normal. It doesnt happen all the time and it just started? Maybe time to up grade the oil pump?
Phill
Love is like a fart; if you have to force it, it's probably shit.
      02-24-2012, 08:34 PM   #2
tekmoe
tekmoe's Avatar
55
Drives: ///M
Is it really the oil pressure light? Reason I ask is because if I am low on oil, I get a light with a beep after I turn the car off. Just wondering if you are mistaking it for that.
      02-25-2012, 09:22 AM   #3
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Yellow or red?
      02-27-2012, 02:28 PM   #4
DataStream18
I am retarded. . . I was just over a half a quart down. . . so far problem solved.
Thanks!
