06-09-2016, 01:15 PM | #1 |
Rep 16
Electrical connector location - passenger door panel
In an effort to find a nagging leak in my passenger door I ended up discovering a previous owner's handiwork.
I'd like to know where the connector that splices from the loom that comes to the door to window switch, rear view mirror, and door panel speaker. You can see it wrapped in the gray foam with electrical tape - I'm almost certain it didn't come from BMW that way. It's different from the driver's side so I can't use that as a comparison. If someone could send a picture where the connector is supposed to go or describe it, I'd like to fix it properly while I already have the sound barrier off. This is for a 2008 Z4 M Coupe if there's any difference between years. Thanks. |
07-05-2016, 05:35 PM | #2 |
Rep 16
It turns out that this is in fact how BMW built the car. To provide some context - this was to fix a water leak. The leak was from water dripping through the small weep hole at the corner of the passenger side side view mirror and window, dripping on to the window regulator, then finding its way to penetrate the adhesive of the sound barrier. It then dripped down the door panel to the foot sill and spilled over. The result was a damp passenger side foot well.
To fix: 1. Remove the door panel 2. Remove the sound barrier 3. Scrape off the old butyl adhesive (pic below of clean door) 4. Remove all remnants of sound barrier 5. Put on new sound barrier (P/N for passenger side: 51-48-7-016-656) 6. Roll on butyl adhesive between sound barrier and door (I used this one: Second Skin Damplifier Butyl Rope (3/8" X 15' Each) 7. Press in the sound barrier to door 8. Put the door panel back on |
07-05-2016, 06:31 PM | #3 |
Rep 2,866
Glad you found the solution...And Thanks for posting a follow up on it
