12-09-2013, 10:41 PM | #1145 |
instagram 997turbotom
279
Rep 7,377
I spent 2 hours with new cobalt drill bits trying to make holes in the rear bumper beam, and couldn't even penetrate one hole. REMOVED the rear bumper beam, put it on my drill press, and broke a new 1/8" drill bit. wow, this is some serious metal
12-10-2013, 06:54 AM | #1146 |
Rep 280
Get better bits. Really. The bumper isn't hardened material!
Also, less pressure, and probably a slower speed. You go too fast and you'll gall up the bit and it won't ever drill properly again. |
12-10-2013, 04:16 PM | #1147 |
279
Rep 7,377
Anyone know what this code means? The car keeps stalling out randomly. Fuel level and voltage seem ok. 12.2v stationary 14.3 or so when running
12-18-2013, 02:08 AM | #1148 |
Rep 912
I have the 5.11inch crank pulley, and 3.06 inch supercharger pulley with a 6pk2360 belt that came with the VT2-500 kit.
I changed as a first step to 6pk2330 as advised by AJ, he told me that this setup should provide 7 PSI peak. At this point, i just stopped understanding how this works, it's either we are all wrong or have problems with our S54 heads or ESS packaging team just don't understand what they are doing when packaging. |
12-18-2013, 06:07 AM | #1149 | |
Rep 5,329
12-18-2013, 08:39 AM | #1150 |
Rep 912
So i have the wrong pulleys for a VT2-500 kit.
Is that correct? can i have a confirmation from more than 1 person ? Also how are you measuring your pulleys? Do you all know that our supercharger bracket flexes and is causing the dreaded belt slip? I'm having my mechanic construct a bracket support in order to reduce the flex a little bit I can move the supercharger around 2 cm with my hand |
12-18-2013, 09:22 AM | #1151 | |
Rep 5,329
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 12-18-2013 at 10:05 AM.. |
12-18-2013, 10:48 AM | #1152 | |
Rep 912
you have 5.11, 3.25 and 6pk2310 I have 5.11, 3.06 and 6pk2360 --> 6pk2330 (after replacement) |
12-18-2013, 12:52 PM | #1153 | |
Rep 5,329
READ WHAT I SED... I DIDNT SAY YOU HAVE INCORRECT PULLIES... ... i sed ess seem to be shipping lots of incorrect parts with these kits, at no point have i said YOUR pullies are incorrect, i have no friggin idea..... all i know is my car makes solid, consistant boost... i do however habe boost upgrade coming....
12-18-2013, 04:01 PM | #1154 | |
Rep 912
I was expecting to have the same setup as you. But it seems that i am far off away from you. |
12-18-2013, 06:00 PM | #1155 |
279
Rep 7,377
3.06" supercharger pulley? That sounds like an odd size. Please re-measure.
I dont believe i have 2cm of play in my bracket either
12-19-2013, 01:59 AM | #1156 |
Rep 912
3.06" supercharger pulley or 3 inch something like that.
It measured 77.9 mm something like that. How do you guys measure? just so that we are on the same page. |
12-19-2013, 12:59 PM | #1157 |
279
Rep 7,377
It should have the size on the back of it written. I will check measurements on my old pulley, i think its about 2mm smaller than full external diameter. Measured on the top of the hills where the belt sits
01-16-2014, 10:47 AM | #1158 |
Rep 5,329
tom.... maybe you should have just swapped out to the 928 billet wheel upgrade for the v3 which around around 2lbs or boost at redline on the same pulley according to their data unless im reading it wrong, this wheel takes the unit to 1200CFM, T-trim lvels of flow...
01-16-2014, 01:22 PM | #1159 | |
279
Rep 7,377
New alternator $750 (wrong diagnosis by me and friend), new fuel pump ~$600, new crank sensor $160, new battery + diagnosis $350, new starter plus install $350. And now I might need to replace my fairly new fuel pump because I had stalling issues a few days ago. as per my other thread "I was told that my 320 CCA, 16lbs battery didn't have enough cranking power and was causing issues. Replaced with a 34lbs 650 CCA battery. Worked fine for a few days Then I had issues with the car stalling after a long drive with some heat soak, and not re-starting. Clicks but no crank. Diagnosed with a bad starter, and they said it was probably killing my small battery. Installed new starter. So car starts fine now, but I had a hard code for low fuel pressure and fuel pump when I brought it in for the starter job. I have a 3 month old Aeromotive 340 pump in the tank, with a new OEM fuel pressure regulator/filter. I'm really upset, and hope that by some miracle the fuel issues were caused by some sort of shorting issues in my starter. I really don't want to replace the fuel pump if I don't have to. I'm hoping the code doesn't come back. Thankfully my fuel pump is under warranty, but this might be the last straw for me if I have to replace it"
01-16-2014, 02:07 PM | #1160 | |
Rep 5,329
oh shit........ sorry to hear this.... ...... ...... cars can be bastard right when the finances are fucked...... good luck and keep us posted!!! i'd noticed youd been very quiet as of recent... good luck buddy. byron
01-16-2014, 04:26 PM | #1161 |
Rep 347
Drives: 2006 BMW M COUPE
Have you guys ha any thoughts as to the point of diminishing returns - I know when drag racing we used to figure that a second on the quarter mile cost about $1000.00 and a sure chance at some point of blowing up the engine.
I know these cars are tough and the engines are almost bullet proof but even F-1 motors will explode and they are also hellish expensive to replace My 5psi kit is all I am gonna push this sucker cause half the attraction is the looks and it don't look great sitting still. Spend another 50 G and get a 014 Stingray with 450hp out of the box and a WARRANTY. If we wanted to build a go fast - we used to get an old body with a very high end drive train and motor and we didn't give a shit if it wrecked - you do get to the point of NO RETURN at some point - guess its fun if you like to push the envelope. Be careful
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
01-16-2014, 05:53 PM | #1162 |
279
Rep 7,377
Its the non-supercharger related stuff thats been breaking for me. I think 520rwhp is a safe level for this engine, tranny, and diff
and I think you mean .1 second costs about $1000, not a full second for a quarter mile Yes, I wouldn't mind having a low mileage Evora S or new Z06 in my garage, but that is double the car payment
01-21-2014, 06:13 PM | #1163 | |
Rep 153
About a 8rib upgrade i got in touch with ca-automotive and they have a kit for the ess kits. |
01-21-2014, 07:41 PM | #1164 | |
Rep 2,176
George |
01-21-2014, 07:59 PM | #1165 |
Rep 347
Yeah - thanks 1/10 second is a grand or thereabouts - if you couldn't mod your car what is the good of it. Have to pick good stuff though - i supercharged another car and it NEVER worked right again - overheating - stalling - disaster - had to take it off
01-22-2014, 01:23 PM | #1166 | |
Rep 5,329
