      01-04-2009, 03:27 PM   #1
izzy
South Africa
13
Drives: ///M Coupe
Braking shudder
Hi,
I am getting a shuddering sensation through the steering wheel when I apply moderate braking force. When I slam on brakes or when I gently brake there is no shudder.
What could be wrong and what do I need to do to mend it?
      01-04-2009, 04:02 PM   #2
Mikewarlover
Mikewarlover's Avatar
Drives: white
Do u track ur car and when is the last time u changed ur brake pad. Its very likely to be ur brake pad which could have worn out otherwise might be u got a warped rotor.
      01-04-2009, 04:18 PM   #3
izzy
South Africa
13
Drives: ///M Coupe
Have not tracked it yet but the warped motor sounds about right to me. Will get the dealer to check it out.
      01-04-2009, 04:35 PM   #4
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
How many miles on the car? If the miles are low it could be an alignment issue.
Best Website EVER!
      01-04-2009, 04:42 PM   #5
izzy
South Africa
13
Drives: ///M Coupe
currently 16 000kms. I got it with 6000km on the clock, so maybe there was some track time during the first 6000kms.
      01-04-2009, 07:59 PM   #6
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Did you just buy the car? It can be a lot of thing's depending on slight differences. Could be un-evenly worn tires to the already mentioned rotor warpage.
Get them hot and see if they start shuddering under hard braking.
      01-04-2009, 08:11 PM   #7
bluetree211
Drives: Audi S6 (C7)
any time Ive had brake shudder, wheel balancing has fixed it.
      01-05-2009, 06:43 AM   #8
DerekSelmanRacing
DerekSelmanRacing's Avatar
Drives: 05 Z4 3.0 SMG, 01 530
Mostly good answers IMO but doubtful on the alignment. Failed front wheel bearing will also manifest itself in brake shudder, but my experience was at harder braking levels.
      01-05-2009, 09:45 AM   #9
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
warped rotors
      01-05-2009, 10:21 AM   #10
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
Originally Posted by MMMazing07 View Post
warped rotors
Having owned a Cooper S, that's what I would think. Not beefy brakes to begin with.
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      01-05-2009, 10:41 AM   #11
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Whenever I've had runout on the rotors, the steering wheel will vibrate as well. The shudder can also be caused by a faulty brake booster.
      01-06-2009, 07:17 PM   #12
DevilM
Drives: 2007 Z4MC Imola Red/Black
Possibly unevenly deposited pad material. Happens when brakes are used lightly.
Try three in a row hard stops from 60 to 10 mph, that should clean the deposits off the rotor.
This is common, and is often blamed on warped rotors.
