08-28-2016, 12:12 AM | #1 |
Rep 195
TCK D/A install questions
I'm in the midst of installing a set of TCKline DA coilovers this weekend that I picked up used. My questions are about the rear spring perch.
I understand the official install is to put the perch on the bottom, directly on the spring carrier. Like so: (not my picture) This metal-to-metal contact with the adjustment tube seems a bit suspect to me. I see that some people suggest turning the spring upside-down and putting the adjuster at the top. Any reason to bolt the adjuster into place through the wishbone, as some have done? Also, I don't have the set screws used to keep the collar from turning on the adjuster. Are they necessary? Appreciate any advice from folks that have experience with this suspension. |
09-18-2016, 11:00 AM | #3 |
Rep 195
Thanks. I have a set of the (very trick) GC adjusters too, but they don't properly fit these springs. I discussed with the shop that did the alignment and corner balancing for me. They are very familiar with the TCK setup and said it worked well, so I just went with it. So far all good.
09-18-2016, 04:29 PM | #4 | |
703
09-19-2016, 11:07 AM | #5 | |
Rep 12,565
09-19-2016, 12:34 PM | #6 | ||
703
09-20-2016, 12:09 AM | #7 |
Rep 195
Interesting that the pic of the spring perch on the Rogue site is with a TCK spring so I assume those would fit. I'll have to revisit this at some point, but I'm in no hurry to pull the rear springs again.
09-20-2016, 01:45 AM | #9 | |
703
I'm heading over to G/C Wednesday so get me whatever questions you have and I'll be happy to run them by Jay. |
