12-27-2021, 04:08 PM | #1 |
Rep 688
Missing Part On Intake?
Am I missing a part here? Nothing is connected and it's just open to the air. This is on a black cover 3.0si. Is there supposed to be a cap? If so any idea what it's called or a part number? Thanks!
12-28-2021, 10:22 AM | #3 | |
Rep 2,706
Definitely not meant to be capped.
12-29-2021, 01:52 PM | #4 |
Rep 688
You were correct, had to take everything back apart and found the hose under wiring. Guess I put it there so it wouldn't get damaged lol. I need to be better about writing things down.
02-18-2022, 11:02 PM | #5 |
Rep 62
Drives: 2007 Z4 3.0si Convertible
I know you figured it out. Just to clarify for anyone in the future. That's the port for the evap purge line from the fuel tank. It connects to a solenoid/valve below the intake which is mounted with the wire harness (as you've seen) and then continues to the fuel tank. If someone gets an evap diagnostic code for the fuel tank or fuel cap, the solenoid is a common culprit.
