      02-29-2016, 11:12 PM   #1
StickMon
StickMon's Avatar
Drives: 2006 MR
Engine Mount Height
Questions have arisen about whose mounts are taller or shorter than whose, so let's have a look.
Don't want to find out that those new mounts you bought cause your PCV line to crash into your strut brace.
Height Summary:
Unloaded, off the car, on the bench:
Stock: 67.4 mm after 30k miles
Vibra Technics: 68.0 mm new
BimmerWorld: 63.5 mm new
Rogue: [TBD]
AKG: 69.1 mm after 2k miles
      02-29-2016, 11:14 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Vibra Technics
The following courtesy of Varinn:
Name:  with studs.jpg
      02-29-2016, 11:17 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
BimmerWorld
I take lousy pictures with 2 hands, let alone 1.
Other assorted dim sums:
Bottom stud length: 20.0 mm
Top stud length: 27.7 mm
Diameter of rubber at top: 67.0 mm
Diameter of rubber in middle: 92.0 mm
Diameter of rubber at bottom: 103.5 mm
Misc. notes:
Has 2 keyholes for heat shield tab.
Comes with stickers and Gummi Bears.
Doesn't come with nuts. Macadamia, Nyloc, or otherwise.
      03-01-2016, 04:41 AM   #4
Beedub
my supercharger intake manifold sat around 10mm away from the SB on the stock mounts, it was always an area what concerned me, but after fitting the VT mounts the distance remained the same between these 2 components.
my stock mounts were removed with very low miles, under 10k for sure, so maybe the squash was small. Pleased to report I've never had a contact issue
      03-01-2016, 12:17 PM   #5
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
StickMon,
Until someone measures a new set of OEM mounts, I thought I could contribute some used measurements. I measured a set of OEM mounts that have 30K miles on them, but look in excellent shape. The battery on my caliper is dead, so this is +/- 1 mm:
OEM 30K Mile Mounts:
Top to bottom thickness excluding bolts: 67 mm
Diameter of rubber at base: 104 mm
Maybe the Bimmerworld mounts are shorter because they don't compress as much, and after compression, the stock mounts are compressed to a shorter height.
Salty
      03-01-2016, 12:37 PM   #6
Drives: M2 Comp
Part of the reason for lower performance mounts is lower center of gravity.
      03-02-2016, 04:23 PM   #7
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
For comparison's sake, and since I'm bored and happen to have it sitting in my living room, here's the specs for the AKG mount. Used roughly 2K miles.
Bolt end to end = 110.44mm
Mount top to bottom = 69.06mm
Top thickness = 60.32mm
Bottom thickness = 89.27mm
Weight with included hardware= 1 lb 4.1oz / 570g
Subtract 1 oz / 28g for hardware
      03-03-2016, 05:56 AM   #8
Drives: M2 Comp
Does it make sense to modify this thread slightly to motor mount spec thread?
Add info for material type ( poly, rubber, etc)
Mount bolt design; (through bolt, isolated, sheer protected, etc)
Might be a good sticky for mount selection
      03-03-2016, 02:10 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
Could, but I think a lot of that is available from the manufacturer.
The height was the main thing I was trying to capture because they never seem to tell you that, and there was a lot of speculation going around.
      03-09-2016, 05:59 AM   #10
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
I vote for stickied thread, good info made better with hard numbers
      03-09-2016, 09:59 AM   #11
SaltyNC
SaltyNC's Avatar
370
I picked up a battery. OEM Mount 30K miles.
Salty
      03-09-2016, 06:19 PM   #12
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Holy shit...they do come with gummy bears
Tags
motor mount dimensions, motor mount height
