03-19-2023, 01:10 PM | #4 |
Rep 429
FYI. z4 3.0si has the same headlights as z4m. Check car-part.com
Perhaps you'll get lucky and find one at a scrap yard in your area. Also try Dan, https://www.zpost.com/forums/showthread.php?t=1956848 |
03-23-2023, 09:44 AM | #5 |
Rep 31
Driver's side headlight
I have a driver's side headlight from my 2008 Z4 3.0si available. It is not in mint condition but very good. It is a halogen headlight w/oem chrome case. Can you use it?
03-29-2023, 01:26 PM | #9 |
Rep 429
If condensation is the only issue I wouldn't be looking for a different headlight. Like brownah mentioned above, there is a cover in the back of the headlight. Its a common problem with the gasket on that cover. But before buying a new one you can try this... take both covers out from both headlights, pull out the gaskets and swap them. BUT flip that gasket flat side up before putting back in. And obviously before closing things up let the moisture completely dry out. It might take a while. Good luck.
