      09-19-2016, 10:06 PM   #1
Cyclops
Cyclops's Avatar
FS: rear Brembo135i brake calipers
USD 300.00
I have an extra set if BMW Performance Brembo 135i rear calipers.
Located in Canada and willing to ship at buyers expense.
Correction
These are not direct bolt on to the Z4. I thought I saw a post were someone put them on but as noted from the source GuidoK some major work it involved to make these work.
DIY custom OEM Rear BBK
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter
      09-20-2016, 01:55 AM   #2
tikamak
Lebanon
58
How big is the rear piston ?
      09-20-2016, 02:45 AM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
These do not bolt up to the regular z4 braking system without extensive modification.
You need at least custom made adaperrings to align the offset and these calipers are more or less designed for a larger rotor than the stock rear rotor
      09-20-2016, 06:44 AM   #4
3002 tii
3002 tii's Avatar
2286
WHS^
You should sell this to 128i users looking to upgrade to 135i calipers
Follow for latest mods
      09-20-2016, 09:14 AM   #5
Cyclops
Cyclops's Avatar
I thought I saw a post were someone made these work but after searching for it I see that the info above is right from the horses mouth.
      09-20-2016, 11:45 AM   #6
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Yes, I made them work on my car. (I once got them in a very good deal from ECS so I just had to give them a try )
But it requires custom made adapterrings to space them out (so work on a lathe), and ideally a larger disk (I use an alternated X3 disk).
Larger disk also means extensive work on the e-brake.
As for the piston diameter I think its 42mm (2 piston caliper)
Selling them to the 1 series public is probably easier (I dont know if its a direct bolt on for the 128i, it has at least a far smaller rear disc than the 135i, and thus maybe also a smaller e-brake system). Maybe it also fits on certain 3 series without major modification, but I'm not sure.
      09-21-2016, 08:43 AM   #7
Blakkflame
Blakkflame's Avatar
Italy
44
Drives: Z4M - E91 MSport
Mmmmmh Guido, I'm not sure (I've Brembo GT), but to fitting on M3 E46 and Z4M, it need only working the pads .....
