      08-09-2011, 11:44 AM   #1
3002 tii
3002 tii's Avatar
2288
Widest Front Tire on 18x8.5 et42?
Can anyone confirm what the widest tire I can run is, on a 18x8.5 et42 on a non-M, stock suspension? I'm willing to add negative camber if necessary, but am concerned that still might not address any strut side clearance issues. I do NOT want to run spacers up front.
Obviously 225/40 would work, but how about 255/35?
Follow for latest mods
      08-09-2011, 12:17 PM   #2
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
this topic sounds familiar...
by chance, have you measured your current strut-side clearance? it might be a good starting point for figuring this out.
| v3.0si | | '08 Z4Coupe 3.0si | BMW Aero | BMW Performance |
      08-09-2011, 12:27 PM   #3
3002 tii
3002 tii's Avatar
2288
Good memory =)
But I'm just getting too many varying opinions on the topic. Consensus seems camber will help with fender issues, but nobody can confirm strut side clearance w/o having to use a spacer.
Will do that this weekend, but my concern is that on paper 255's might fit but on hard cornering or on the track, it may still rub...
      08-09-2011, 01:53 PM   #4
v3.0si
v3.0si's Avatar
i didn't want to wait, so i'm using mine as a base line...
alright. maths.
8.0" et34 w/ 225/40 tread is producing ~25mm clearance from the strut to the inner edge of the tire on full left-hand lock (LF wheel was used for measuring).
if i were to install your wheel, the inner edge would be 14mm closer to the strut.
and an additional 15mm for a 225 --> 255 tread (255-225=30... 30/2=15).
~25mm definite clearance compared to 29mm loss = ~4mm deflection of the tire on the strut. and this is assuming the sidewall cross-section doesn't change.
methinks a minimum of a 5mm spacer is required, maybe bigger. hell, at ~4mm, a 245 tread may still rub without a spacer.
dubbe, i think you're hosed. but i really want you to prove all this wrong... i would love to put some 255 tread up front!
      08-09-2011, 02:01 PM   #5
v3.0si
v3.0si's Avatar
i'm surprised you haven't done a test fit with one of your rears yet. jack it up and flip 'em already!
      08-09-2011, 02:10 PM   #6
3002 tii
3002 tii's Avatar
2288
I'm not that lazy, ha... I have 225 on all 4's now. Will report back with my findings...
      08-09-2011, 02:33 PM   #7
v3.0si
v3.0si's Avatar
ohhh... i see.
and i've always wanted to use this...
