      11-22-2008, 09:35 AM   #1
<<M>>
Drives: z4
brand new car, couple of concerns already
So I have a brand new Z4 M Roadster, and the cigarette lighter port has some black rough stuff at the bottom, doesn't wipe out with my finger.
I can get it swapped out for a new part, but my friends identically new M Roadster also has this stuff. Both of our cig lighters do not power up accessories
Has anyone else seen this black stuff on the cig lighter power ports on their bmws?
Also, still learning about the car, and I don't see this info in manual:
Does passenger side rear view mirror not go down when you put car into reverse? This would be the first modern BMW that I've seen that doesn't have that feature.
My headlight washer nozzle cap flew off on the highway, does anyone know the fuse number for the headlight washers? I'm going to deactivate them as they don't seem to do much to clear the headlight anyway.
Do any Z4s come from the factory with an alarm system? My friends and my cars both only have prewiring. (strangely his rearview mirror red LED light flashes when locked, mine does nothing).
Obviously there are many many things I love about the car so far, but these were a few things on my mind that I couldn't find answers to by RTFM!
      11-22-2008, 09:44 AM   #2
skierman64
skierman64's Avatar
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
Regarding the right hand mirror, it won't tilt down if the adjustment switch is set to the right mirror. You must have the left mirror selected for the mirror to tilt down.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      11-22-2008, 10:08 AM   #3
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Z4 mirrors don't tilt, no matter how the switch is set.
      11-22-2008, 06:02 PM   #4
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
Not sure about the black stuff, but the cig lighter can be a bitch to get powering up accessories in general. I think the best way to tell if it works properly is plug in your M Mobility Kit compressor. If that doesn't work the dealer should replace it. If it does work, you'll just need to give your other accessory plug lots of jiggles and turns to get working...
The Z4 models don't have this feature.
Not sure on this one but if I remember correctly the fuse diagram is above the glove box.
The car comes prewired, but not with the alarm installed. The clown nose is a dealer programable option, so you can have them fix that if you want.
Answers in red!
Best Website EVER!
      11-24-2008, 11:30 PM   #5
<<M>>
Drives: z4
Thanks for taking the time!
      11-25-2008, 03:27 PM   #6
Hawkeye
Hawkeye's Avatar
No_Country
2070
I believe if you have "audible" set on your car (through the dealer) it will not beep when you lock/unlock your car without an alarm installed but it will flash the lights and the clown nose will also flash (after about 90 seconds)
