      12-18-2012, 07:11 AM   #111
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Originally Posted by BMW Maniac View Post
The engine is seeing "x" amount of air, and is delivering "y" amount of fuel. "Y" is either correct according to the tune, according to what the ECU thinks the engine is seeing via the MAF, or what is limited by the fuel system.
Here is how I'd attack it and whenever I have problems on my turbo M3, this is my methodology:
1) Vac test.....usually, in boost, the engine will run rich because the accounted for air is leaking out in boost, but the fuel has already been provided...still, always check first and eliminate this as a potential issue...many people also want to assume away this problem...smoke test!
2) Fuel pressure check...what should it be idle, accelerating, in boost? Need to verify the fuel pump, FPR, injectors are all in compliance.
Good luck, and please let us know what you find out once this is resolved!
Great info! Simple and to the point.
      12-18-2012, 10:58 AM   #112
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
The 570 is MAF less, but I'm not sure if it's running a set map at WOT (open loop). I'll have to do some research and see if this specific ECU runs in open loop ever. If VF can't fix the issue with tuning, then I'll definitely have to do pressure tests to make sure everything is up to par.
      12-21-2012, 03:43 PM   #113
johanness
Drives: 2008 Z4MC
Have VF responded to this yet? They've posted on other threads, but you'd think they would want to get to the bottom of this ASAP.
      12-21-2012, 04:30 PM   #114
Rated M Roadster
160
VF is taking care of me; all is well. I also ordered some new gauges that should arrive next week (AFR and boost).
      12-24-2012, 06:33 PM   #115
Beedub
any news???
      12-25-2012, 04:53 AM   #116
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
btw whats the new 0-60 time with a sc z4m, I wanna hear it from you guys
      12-25-2012, 10:25 AM   #117
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Officially? I've nailed a 4.2seconds run in cold weather, before I knew how to launch, and tires weren't gripping
Theoretically? High 3's, with a monster launch on hot tires on warm road, with temperatures between 60*F and 70*F, lol
Mathematically based on my best run?
60' 330 1/8 mph 1000' et mph
1.86 5.22 7.93 92.16 10.23 12.170 116.42
plug that into here http://forums.corvetteforum.com/c6-t...alculator.html
and you get 3.97 seconds
I'm making about 400rwhp on that run
      12-25-2012, 11:16 AM   #118
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
0-60 is a useless way to measure proper acceleration. All depends on 1-2 gearing. 1/4 mile or rolling starts are more accurate to display power
instagram: @ dubsesd
      12-25-2012, 01:25 PM   #119
Beedub
i dunno, its a great marker as its an industry standard, however i like the 30-130 number ;-)
      12-25-2012, 08:03 PM   #120
beta
Drives: 2006 M Roadster
De-railing the thread, but if you want absolute best launch times you want either a racelogic traction control unit, or proefi traction control (which also gives you flex fuel and a few other cool features). I think both will also do launch control and flat shifting, where you can just keep it floored from start/between shifts.
Don't think anyone has fitted these to our ECUs though. Since those units cut fuel/spark, the built in ECU will see it as a fault, so you need a special tune. I think CA-Auto out of the UK can do the racelogic unit.
      12-25-2012, 08:50 PM   #121
Z4-VILLA
Afghanistan
111
my buddy just got an f430 so I was wondering if we were in super car territory with the Supercharging stuff
      12-26-2012, 01:22 AM   #122
beta
F430 is 20kg lighter, has NA 483 hp (roughly 410 wheel), 285 rear tires and significantly better downforce.
On paper with some supporting mods you could get close. In a practical sense, at that power level, it comes down to the faster driver.
      12-26-2012, 01:35 AM   #123
Z4-VILLA
Afghanistan
111
yeah i was looking at the z4m in a different light this weekend. Im undertaking a huge logistical undertaking with the Carbon Fiber doors in the Cosmetic thread...should drop a solid 50 lbs off the car. FI will be my final step. I think if done right our cars can dive deep into supr car territory. then theres HPF.....lord knows when that will be finished.
      12-26-2012, 02:46 AM   #124
Beedub
i thought you already had VT1??
either way, these s/c z4ms with the right supporting mods really make nice cars...
      12-26-2012, 04:39 AM   #125
Z4-VILLA
Afghanistan
111
its on the burner...Doing the CF doors things first.
      12-26-2012, 04:42 AM   #126
Beedub
cool, weight loss, some nice suspension mods, power last... i actually think dropping as much weight as possible, running the base kits, will yeild a more balanced car.... and a much less stressed one....
      12-29-2012, 12:04 PM   #127
Beedub
Originally Posted by Beedub
any news???
^^^^^^^^^ this.
      01-03-2013, 12:22 PM   #128
Beedub
oh no...... is this another s/c thread that will disappear into the distance??
any news rated??? good or bad, keep us updated.
      01-03-2013, 12:58 PM   #129
Rated M Roadster
160
I've been enjoying the holidays with family. The kit has almost 1000 miles on it and is running great. I've also been working with an awesome photographer on something special.
      01-03-2013, 02:05 PM   #130
Beedub
awesome stuff..... what about the fueling thing?? sorted now??
      01-03-2013, 03:52 PM   #131
Geauxkart
Geauxkart's Avatar
13
Drives: 2007 Z4 M Coupe Sepang
Well, that's nice and all - BUT, we all want to know about the fueling issues!
Yes it looks good by camera, but I wouldn't run it on my car as the data shows right now.
The one negative VF has is the tuning history - and the blown engines.
I know it was outsourced in the past, and is now done in house. $ / HP, this is the best kit out there, but if it's going to damage the engine at high RPM, I wouldn't run it myself.
Please let us know what you find out!
      01-04-2013, 03:21 PM   #132
Will@P
Drives: M5
Yes, all tuning is done in house (Past GIAC) and has been working exceptionally well. We have flash tuned multiple NA cars, a VF620 E92 M3, and very soon a supercharged E46 325i with VF software and have had no issues.
If there are any Florida members interested in pursuing a VF570 kit please let me know as I have been looking for a candidate to get one installed, dyno numbers, and get another review out for everyone. I know a lot of you are itching to pull the trigger!
