      08-27-2016, 05:31 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
Disappointed - coolant hose quick disconnects - any options?
Really hate dealing with these quick disconnects. Was hoping there were some conversion kits or quick disconnect hose ends which allowed me to go back to regular barb and hose clamps.
These things are always a nightmare to remove. Can anyone recommend aluminum quick-disconnect hose ends with a barb on the other end?
Or, perhaps someone has a secret to keeping these from sticking after a few heat cycles?
      08-27-2016, 06:23 PM   #2
Steeler
Steeler's Avatar
2429
I have had mine off annually the last 3 years doing under hood mods.
I always put a light coating of petroleum jelly on the male fitting upon reassembly
Have not had issues removing.
      08-27-2016, 06:58 PM   #3
dre99gsx
These have probably been on here for tens of thousands of miles (90k mi on the odometer). Good to hear that if they are lubed and "frequently" removed/inserted, that they come off easily. I will most likely being doing constant mods on this vehicle and doing the same as you with these hoses. Petroleum jelly the best for this vs. grease?
      08-27-2016, 07:29 PM   #4
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
I used it in similar applications on my Z3. I would say so and corroborate on the use of petroleum jelly.
◙ Shane
      09-01-2016, 04:48 PM   #5
Clearancediver
Drives: 2004 Z4
I used a silicone lube....
Sent from my smart phone...
      09-01-2016, 05:08 PM   #6
GuidoK
#buildnotbought
GuidoK's Avatar
10847
Drives: Z4 3.0i ESS TS2+
i also use silicone lube but that doenst really work. I feel Andre's frustration. I've had them on and off quite frequently (6 months or so) and with silicone lube but that doesnt really work. The silicone lube does make them go on real easy but after 6 months its mostly same old same old.
The cooling hoses can be a pain (I use penetrating oil before attempting) but getting the coolant reservoir off the radiator is a REAL pain.
But hoses on barbs also can get stuck. but then at least you can get a hook under there and rotate around the barb loosening it.
I think a 100% conversion will be difficult though (because of the room aquired)
I've never seen an adapter from the bmw system to a barb or so.
      09-01-2016, 06:57 PM   #7
Steeler
Steeler's Avatar
2429
I had an issue with the blower belt rubbing on my upper rad hose.
Bought 2-45 degree 1.5" odd aluminum elbows from Summit Racing and fashioned a new upper hose
The ends can be disassembled should the push lock fitting get seized
The factory push lock ends have a ribbed end once the OEM hose is removed
Might suit your needs Andre
