03-04-2016, 12:38 PM | #1 |
Rep 26
Overheating..again
Hello all.
So the Z4 Coupe 3.0si is over heating again. it has 86k miles on it. I have replaced the expansion tank and thermostat (both with OEM parts) I have noticed a trend on very cold days when it over heats. Here is what happens: 1. Start the car (sitting over night) and the small engine fan starts to run from the start and car runs a bit ruff 2. Car takes a longer time to get to operating temperature temp (needle in the middle) 3. Car has no heat for approx 10mins after reached operating temperature. After 10mins the heat starts slowly 4. 5 mins after the heater starts working the car starts to over heat 5. Overheating temperature fluctuates depending on driving conditions. After a few minutes the temp gets hotter. Has anyone experienced similar conditions. Next on tap is to replace water pump and coolant temp sensor (lower rad hose) Will this fix the issue or should I be replacing other things? Help is much appreciated....thank you
E86 -Tint, LED's, Front Clear Corners, Rear Red Turn Signals, Proclip, ZHP Shift Knob, Sebring Exhaust
"Friends Don't Let Friends Drive Stock" |
03-04-2016, 01:05 PM | #2 |
Rep 11,667
Same behaviour pre/post parts replacement?
03-04-2016, 01:22 PM | #3 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Could be the water pump isn't performing well and isn't circulating the water through the heater coil very well (nor circulating cool water to the engine). It may be flowing but very poorly.
But #2 -- hmm. Salty
03-04-2016, 01:24 PM | #4 |
Rep 11,667
^agreed.
& With that mileage the cooling system should be updated if still original
03-04-2016, 01:54 PM | #5 |
Rep 26
Had the same issues before replacing the Expansion Tank and Thermostat. After replacing those..had no issues for 6 months. Then yesterday it happened again. Have not driven it since then
03-04-2016, 03:19 PM | #6 |
Rep 2,702
Air lock?
03-04-2016, 08:44 PM | #7 |
10626
Rep 4,848
I know the thermostat is partly controlled by the ecu. For that it needs temp sensors. There's one in the hose, but I think there's also one in the block (cylinder head).
Replacing (or checking) the waterpump is definately a good idea. But it's strange that you hadn't had the problems for 6 months, and now that it's cold you get these strange symptoms again. Interesting problem. I dont know if the waterpump is also ecu controlled or that it's always on, but to me it sounds like either both waterpump and thermostat (so open (broken) thermostat prevents the engine to heat up quickly and the broken waterpump prevents enough flow that results in overheating), or a temp sensor and thermostat (thermostat still stuck open and inaccurate temp sensor prevents accurate waterpump control). Or that air lock (but after 6 months?) And what do you mean with the " and the small engine fan starts to run"? I thought it only had one fan on the radiator and it's quite large?
03-07-2016, 12:53 PM | #8 |
Rep 26
I believe there are 2 fans...there maybe a smaller fan close to the bigger fan. It sound like a fan..and is also present for approx 5 seconds after the car is off
03-07-2016, 03:20 PM | #9 |
Rep 26
I'm looking at replacing the following parts. Can someone give me some feedback if these are good reliable brands? I don't track my car. Just street use...thanks
PART #: A0340B | OEM #: 11517586925 : Electric Water Pump, PIERBURG : $505.00 PART #: B0340B | OEM #: 11510392553 : Aluminum Bolts for Water Pump : $10.00 PART #: 11626B | OEM #: 34116779652 : Ceramic Front Brake Pad Set, BREMBO: $99.00 / set PART #: 70286B | OEM #: 34357836795 : Front Brake Wear Sensor, OEM: $15.00 PART #: 31271B | OEM #: 11287628651 : Serpentine Belt, CONTITECH : $30.00 PART #: 4011B | OEM #: 13621433077 : Temperature Sensor, OEM : $30.00
03-07-2016, 04:34 PM | #10 |
Commander
219
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Are you sourcing these from Worldpac by chance ?
Only thing I have used myself the belt itself, my E46 has it and no issues, honestly, for daily driving I think these will serve you just fine. That water pump is not much different from what an OEM one at package price is at the dealer too.
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
03-07-2016, 10:14 PM | #11 | |
Rep 26
03-08-2016, 08:15 AM | #12 |
Commander
219
Rep 850
I may be wrong but I believe the OEM pads are actually made by Textar.
03-08-2016, 10:28 AM | #13 |
Rep 1,483
OEM pads are Textar. They are very dusty IMO, I bought a set of Stoptechs and really like them.
- Instagram ->@e91kiter |
04-20-2016, 10:33 AM | #14 |
Rep 26
Thanks for your help all.
My INDY scanned for codes and it was a water pump failure. Although there was no check engine light, there still was a code when scanned. Ended up replacing: water pump, lower rad hose & sensor, Serpentine belt, brakes, coolant. New owner should be happy
