      11-03-2015, 07:44 PM   #1
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
Clutch Replacement
Has anyone replaced thier clutch, pressure plate and throw out bearing? My throw out is crapping out and I am thinking might as well do it all. I had sone cluch changes on my E30 M3 and really can't see this would be any different. Is there anyone outh there to give me their knowledge? Any help would be great
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      11-03-2015, 08:41 PM   #2
an3ony
an3ony's Avatar
Drives: 2011 135i
Your best bet it to change the whole shebang while you're in there. Also, put some thought in changing out the rear main seal too. At the very least, change out that clutch friction disk with the T/O bearing.
Side note, if you change out the clutch parts, remember to get new pressure plate bolts, they're stretch bolts and really should be changed.
      11-04-2015, 02:34 AM   #3
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
My Z had it's clutch replaced, by I let the dealership do it. I recommend replacing the clutch and pressure plate while you're in there changing the throw out bearing. The parts aren't that expensive.
      11-18-2015, 08:08 PM   #4
Clearancediver
Drives: 2004 Z4
Machine flywheel....
Sent from my smart phone...
      01-16-2016, 02:28 PM   #5
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Searched and didn't find much info (mind you haven't looked into the e46 forums yet).
My clutch is starting to go...so I'm starting to look up replacements. Since this is my casual driver that I intend to supercharge, I figured upgrading the clutch should be done at the time I replace it. I haven't been able to find much information.
I'm hoping to get a single mass lightened flywheel, is this possible? Also, what are my options. Are there stage two clutch kits?
6 speed paired to M54B30.
      01-16-2016, 03:25 PM   #6
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
I have a review out there on my lightweight flywheel setup. I'm going to have to sell it within the next year and move to a solid steel flywheel, if I can find it. The car is a blast to drive with the lightweight flywheel, but I'm about to build the motor for 15 psi of boost and am concerned about harmonic vibrations. If you decide on a lightweight flywheel, I would recommend moving to the ATI super damper from VAC at the same time.
