08-27-2013, 05:16 PM | #1 |
Rep 2,657
APEX | Wheel Spacers available for your BMW/Free shipping to the U.S. 48!
APEX Wheel Spacers
APEX BMW wheel spacers for all 5 lug BMW models except for the E39. These spacers are machined from billet aluminum and made in Europe by a TUV certified ISO9001 manufacturer. Perfect for adding needed suspension clearance between your wheels/tires, or to push your wheels out for a more aggressive look. Spacers are sold in pairs of 2, and cannot be used with stock length lug bolts. Extended lugs or a stud conversion is required to use spacers. All Wheel Spacers
5mm Wheel Spacers
5mm BMW Wheel Spacers - $49.99 12mm, 15mm, and 20mm Wheel Spacers
12mm BMW Wheel Spacers - $84.99 15mm BMW Wheel Spacers - $94.99 20mm BMW Wheel Spacers - $94.99 Mandatory Extended Length Mounting Hardware BMW Stud Conversion Kits and OEM Style Extended Lugs
RAD Extended Wheel Locks
Ordering and Contact
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 02-28-2014 at 01:16 PM.. |
08-27-2013, 07:57 PM | #2 |
#dubspec
6328
Rep 5,200
My wheel hub center sticks out 15mm. 2 sets of 10mm spacers only allow for 12.5mm of hub extension and my 15mm spacer works fine. Does your 12mm spacer have enough room to clear my hub center. This is on a BMW e90 lci, which I heard have varying hubs
10-01-2013, 02:44 PM | #3 |
Wagon life
39
Rep 991
11-20-2013, 06:20 PM | #4 |
Rep 2,657
APEX is now offering RAD Extended Wheel Locks!
Please contact us if you have any questions! We have not seen any issues with the 12mm spacer on LCI E90's and we've sold many wheels and spacers in this market. The 12mm spacer has a 16.5mm depth for the hub to fit under, so I am 99% confident that our 12mm spacers will fit your application with no issue. We do have an E90 LCI in house that we can measure and test next time it is up on the lift to give you an update.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 02-28-2014 at 01:21 PM.. |
05-06-2014, 04:59 PM | #5 |
Rep 2,657
Having trouble with your fitment? Give us a call so we can better help you and recommend the proper spacer for your application.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
05-06-2014, 05:12 PM | #6 |
#dubspec
6328
Rep 5,200
Do 5mm spacers work on the front of Z4m hub and retain enough material to rest the wheel?
05-06-2014, 06:05 PM | #7 |
Rep 6,731
Yes they sure do, we have had many Z4M customers use our 5mm spacers without any issues with our hubcentric wheels.
06-27-2014, 07:44 PM | #8 |
Rep 6,731
Wheel spacers can be a great aid in providing adequate clearance against aftermarket suspension components.
Please call, email, or pm us with any questions you may have.
07-01-2014, 06:19 PM | #9 |
Rep 2,657
Make sure you purchase the correct length lug bolts for your spacers! These are available individually or at a discounted price when purchased along with a spacer kit!
Please let us know if you have any questions about our wheels or accessories and we'd be glad to help you out!
08-12-2014, 08:24 PM | #10 |
Rep 6,731
Fitment issues? Wheel spacers may be just what you need to get the required clearance against a modified suspension.
Please call, email, or pm us with any questions you may have. |
09-05-2014, 06:08 PM | #11 |
Rep 2,657
Wheel spacers are in stock for your E46! We have 5, 12, 15, and 20mm sizes.
Please call, pm, or email us with any questions you may have about wheel fitment or suspension clearance issues. |
10-03-2014, 05:58 PM | #12 |
Rep 2,657
Want to push the wheels out more flush to the fender? We've got the answer here, spacers in various sizes available!
20mm spacers in photo above
