Go Back   ZPOST > Marketplace > Sponsors Classifieds
      08-27-2013, 05:16 PM   #1
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
APEX | Wheel Spacers available for your BMW/Free shipping to the U.S. 48!
APEX Wheel Spacers
APEX BMW wheel spacers for all 5 lug BMW models except for the E39. These spacers are machined from billet aluminum and made in Europe by a TUV certified ISO9001 manufacturer. Perfect for adding needed suspension clearance between your wheels/tires, or to push your wheels out for a more aggressive look. Spacers are sold in pairs of 2, and cannot be used with stock length lug bolts. Extended lugs or a stud conversion is required to use spacers.
All Wheel Spacers
  • Can be used in any discipline: Street, Auto X, Track, and Racing
  • 5x120 bolt pattern
  • 72.6mm center bore
  • Billet aluminum
  • Anodized Finish
  • Made in Europe
5mm Wheel Spacers
  • These 5mm spacers have been tested with the APEX ARC-8 wheels.
  • There is still enough material on the OEM hub to keep wheels hub-centric and vibration free.
5mm BMW Wheel Spacers - $49.99
12mm, 15mm, and 20mm Wheel Spacers
  • APEX 12, 15, and 20mm spacers are a true hub-centric design, and a must when a proper, issue-free fitment is required. The extended hub keeps your wheels centered properly which eliminates wobble and vibration inherent in traditional spacers.
  • Without a hub extender the wheel is only secured by the lugs (known as lug centric) when a spacer is used. BMW's were not designed to be lug centric, as they have a lot of slop/play around the lugs.
  • This is the same reason why some wheel manufacturers have to provide centering rings if their wheels are not 100% BMW specific. If you don't want your car to ride like a wagon, you need hub-centric spacers.
12mm BMW Wheel Spacers - $84.99
15mm BMW Wheel Spacers - $94.99
20mm BMW Wheel Spacers - $94.99
Mandatory Extended Length Mounting Hardware
BMW Stud Conversion Kits and OEM Style Extended Lugs
  • When using any of our wheel spacers, extended length mounting hardware is required. OEM lug bolts do not have enough length to go through the spacer, and thread into the hub. Either longer OEM style lug bolts, or a stud conversion is required.
  • Both options allow for proper thread engagement. Using hardware that is too short can cause failure of lug bolts.
  • On our website you can add a set of 10 extended lug bolts to your order at a discounted price by selecting your desired finish from the drop down menu. This is enough for two spacers or two wheels. These lugs bolts are either 5, 12, 15, or 20mm longer than the OEM lugs that come on BMW's from the factory and they share the same 12x1.5 threads and 60 degree taper.
  • Available in a black or silver zinc finish. Additional lugs can also be purchased individually.
RAD Extended Wheel Locks
  • Available in multiple lengths, RAD wheel locks are a must if you're using spacers. OEM length wheel locks do not have the required length to thread into the hub with a spacer installed. These can cover 3, 5, 12, 15, 18, and 20mm spacers.
  • RAD Extended Wheel Locks allow for proper thread engagement. Using hardware that is too short can cause failure of lug bolts.
  • RAD Extended Wheel Locks are all made in Germany and Dacromet coated for protection against the natural elements.
  • 100% Quality inspection before delivery.
  • Extensive selection of unique wheel keys in multiple sizes, which makes it much more difficult to defeat compared to “one-size-fits-all” solutions from other manufactures.
  • Sold in sets of 4, RAD Extended Wheel Locks can provide protection for all of the wheels on your car.
  • NOTE: These are available in M12x1.5 thread pitch only and will not fit 2012+ BMW F30 3-Series, 2011+ BMW F10 5-Series & M5, 2012+ BMW F13 6-Series & M6, or 2009+ BMW F01 7-Series as these vehicles have use M14x1.25 thread pitch.
Ordering and Contact
  • Phone: Call (888) 499-9135 EXT. #1 for phone orders.
  • Payment: Credit and Debit Cards: Visa, Mastercard, AMEX, Discover, PayPal. Bank Wire Transfers are also available. Contact us to use a wire transfer for payment on your order.
  • Tax: California customers will be charged 9% CA sales tax.
  • Shipping: Free shipping only to domestic orders within the lower 48 states. We do ship internationally!
  • APEX Hours:
    Monday thru Friday: 9AM to 5PM PST
    Saturday and Sunday: Closed
  • Warehouse and local pickup: The APEX warehouse is at 7888 Marathon Drive, Unit A, Livermore, CA, 94550 (Map It), (888) 499-9135 EXT. #2. This is where you pick up local orders.
      08-27-2013, 07:57 PM   #2
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
My wheel hub center sticks out 15mm. 2 sets of 10mm spacers only allow for 12.5mm of hub extension and my 15mm spacer works fine. Does your 12mm spacer have enough room to clear my hub center. This is on a BMW e90 lci, which I heard have varying hubs
instagram: @ dubsesd
      10-01-2013, 02:44 PM   #3
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Originally Posted by ApexRaceParts View Post
Wheel spacers are in stock for your BMW to get that perfect wheel fitment!
Please call, email, or pm us with any questions you may have.
LOL @ the backwards tire :P
      11-20-2013, 06:20 PM   #4
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
APEX is now offering RAD Extended Wheel Locks!
Please contact us if you have any questions!
We have not seen any issues with the 12mm spacer on LCI E90's and we've sold many wheels and spacers in this market. The 12mm spacer has a 16.5mm depth for the hub to fit under, so I am 99% confident that our 12mm spacers will fit your application with no issue. We do have an E90 LCI in house that we can measure and test next time it is up on the lift to give you an update.
      05-06-2014, 04:59 PM   #5
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Having trouble with your fitment? Give us a call so we can better help you and recommend the proper spacer for your application.
      05-06-2014, 05:12 PM   #6
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
Do 5mm spacers work on the front of Z4m hub and retain enough material to rest the wheel?
      05-06-2014, 06:05 PM   #7
Expert@ApexWheels
Expert@ApexWheels's Avatar
3523
Drives: M3
Yes they sure do, we have had many Z4M customers use our 5mm spacers without any issues with our hubcentric wheels.
      06-27-2014, 07:44 PM   #8
Expert@ApexWheels
3523
Drives: M3
Wheel spacers can be a great aid in providing adequate clearance against aftermarket suspension components.
      07-01-2014, 06:19 PM   #9
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Make sure you purchase the correct length lug bolts for your spacers! These are available individually or at a discounted price when purchased along with a spacer kit!
Please let us know if you have any questions about our wheels or accessories and we'd be glad to help you out!
      08-12-2014, 08:24 PM   #10
Expert@ApexWheels
3523
Drives: M3
Fitment issues? Wheel spacers may be just what you need to get the required clearance against a modified suspension.
      09-05-2014, 06:08 PM   #11
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Wheel spacers are in stock for your E46! We have 5, 12, 15, and 20mm sizes.
Please call, pm, or email us with any questions you may have about wheel fitment or suspension clearance issues.
      10-03-2014, 05:58 PM   #12
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
Want to push the wheels out more flush to the fender? We've got the answer here, spacers in various sizes available!
20mm spacers in photo above
