      07-20-2014, 09:03 PM   #1
just2talented
just2talented's Avatar
Drives: Alpine ///M roadster
Need Some Help. Multiple Warning Lights
Ive searched the other threads of of similar issues but I think mine might be a little different.
I intermittently get a YELLOW ABS light, a RED HAND BRAKE LIGHT, a YELLOW TPMS LIGHT and a YELLOW TRACTION CONTROL LIGHT.
All lights come on at exactly the same time, usually at around 3-3500 RPM. When they come on, I can notice a very slight drop in power and my radio cuts out but does not shut off, just no sound, time still shows.
I had one mechanic run obd to see what codes popped up, he got some voltage warning codes but he couldn't confirm exactly what it was.
Having read the other forums, im starting to think its either the voltage regulator, or the whole entire alternator.
Im also gathering that it could be a wheel speed sensor or a dsc module, or a abs monitor, or the MAF sensor?
if somebody can help me out, id be very very thankful!
      07-21-2014, 12:23 AM   #2
Clearancediver
Drives: 2004 Z4
I would check your alternator to see if it's the voltage regulator. Check output voltage at idle and at 1500/2500 etc..... Does the voltage stay the same or does it increase with increase in rpm.... If it increases in a consistent manner it's likely the voltage regulator is not working. Voltage output should be in the 13.7 - 14.5 range.
Sent from my smart phone...
      07-21-2014, 12:27 AM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
I believe this is exactly what you'd see with:
Alternator
Voltage regulator
Including the rev range link. Trick is properly diagnosing. Have a look here. Discussed in great detail. http://www.zpost.com/forums/showthread.php?t=669131
      07-21-2014, 01:01 AM   #4
donoman
Rookie
31
Drives: 03 Z4 2.5i 5MT
Try to turn the headlights and AC on to load the system as much as possible and see if it does this more than without a load on the system. It's hard to determine what is going bad but you will be able to electrically test these components, I believe.
You can pull your MAF, ABS, etc fuses to temporarily disable those systems to isolate the cause of the voltage drop.
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      07-25-2014, 05:34 PM   #5
mbanshchikov
mbanshchikov's Avatar
14
Drives: 2018 M2
is your roll back hold working?
2018 BMW M2
2018 Honda Clarity
