      04-13-2013, 05:30 PM   #1
dean911
Drives: '07 Z4 M Coupe
Brain fart bleeding the brakes
Yep, you guessed it. Didn’t keep the reservoir filled.
I got side tracked before doing the last wheel and thought I had filled up the reservoir. Filling my last cup with a hand vac pump and I hear the gurgling sound. Topped it off and sucked out a second cup of fluid out of the caliper but no good. Now the brakes are like mush. I believe I sucked air into the ABS unit.
Been doing brakes forever but never did this before. Can I fix this at home or is it time for the dealer?
Oops!
      04-18-2013, 11:55 AM   #2
Ovaltine
floor sweeper
Drives: 2007 Z4 Coupe
On an E36 you can manually control the ABS pump by pulling the ASC (or DSC?) relay and shorting the contacts. This would allow you to cycle fluid through and purge the air. I'm not sure if there's an equivalent method for the Z4 or not. If not, the dealer is the safe bet. They'll use their scan tool to cycle the ABS pump.
      04-18-2013, 12:07 PM   #3
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
Could you possibly activate the ABS and cycle it by doing panic stops?
      04-18-2013, 12:29 PM   #4
Ovaltine
floor sweeper
Good idea. Panic stops (or even regular stops) in grass for the full ABS effect.
      04-18-2013, 01:07 PM   #5
The HACK
The HACK's Avatar
1821
Any independent mechanic with access to a GT1 machine can hook it up and get the ABS pump to manually cycle.
