      03-22-2016, 12:01 AM   #23
Dalecan
Dalecan's Avatar
102
Drives: Aston V8VS, F85 X5M, TVR, 128i
That's expensive for a valve adjustment. What else did they do for that price. I haven't had to pay for that yet as it was done under warrenty and the car only has 45k on the clock.
      03-22-2016, 12:48 AM   #24
StickMon
StickMon's Avatar
Drives: 2006 MR
Wow!
Just think about how many tools you can buy for $1250!
Less than 1/2 of that will buy you all the tools and consumables you need to do it yourself, the first time.
After that, it's about $100 in consumables.
It's time consuming, but not very difficult, and you know that it got done.
The thing that bothers me about something like a valve adjustment is that the car is running fine when you bring it in and fine when you drive it out.
Did they even open the hood?
When I tell people I work on my own car they always ask "Don't you need a lot of expensive tools like torque wrenches and stuff?"
My answer is "Do you realize how many torque wrenches you can buy for what you're paying in labor?".
      06-22-2017, 07:16 AM   #25
scrammer
scrammer's Avatar
Drives: 2017 M3 Ultimate
Originally Posted by knsaber View Post
I might just have to do this with my OEM to get rid of the drone from my Magnaflow!
Did you come up with a solution for the Magnaflow drone or did you go with the oem mod?
I am reluctant to cut up the expensive oems when MFs are so cheap to install. My local shop will charge around the same $$$ for the project either way ... and the MFs are easily reversible for future re-sale...
Current ///M: 2017 M3 Ultimate
Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3
      06-22-2017, 10:41 AM   #26
WeekendWarriorz
WeekendWarriorz's Avatar
670
Drives: 2006 Z4M
Originally Posted by StickMon View Post
Wow!
There's a guy in Glendale, CA that does valve adjustments starting at $400... And he has a HPF turbo M3...
