      02-02-2020, 05:49 AM   #1
JimBob0047
Drives: 2006 Z4MR
S54 Vanos Bullet Proofing
Vanos overhaul Completed yesterday. Everything was squeaky clean and tight with 63k on the motor. No loose cam bolts and no broken exhaust hub tabs. Only wear item was the chain tensioner and probably would have snapped in the next 20k miles. Vanos rattle is gone and car doesn't flatline between 7.5 and 8k anymore. If anyone local to the DMV area is looking for this service you must have DAFOE do it. Top notch guy and could probably do it with his eyes closed. This was the last preventative maintenance item on the list and now we wait for Turners new carbon air box, OEM catless headers and TTFS tune.
AK72286.00
kaybat125.50
      06-24-2020, 05:08 PM   #2
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Is there a kit for the entire overhaul? Tabs, bolts, etc
parts cost & labor hours if you don't mind sharing?
Thinking of doing this this summer...
      06-24-2020, 06:05 PM   #3
JimBob0047
Drives: 2006 Z4MR
Here's the parts list
Beisan
Http://beisansystems.com/products.html
S54 vanos oil pump disk
S54 vanos seals repairs kit
S54 vanos sealing plate repair kit
S54 rebuilt vanos solenoid pack (optional)
S54 exhaust upper chain guide
Related Vanos Parts - ECS
(12) updated cam bolts 07129905536
(1) Vanos gasket tel:11367831938
(2) Oil return washers tel:07119963129
(2) Vanos oil return washers tel:07119963072
(1) Crankshaft chain tensioner washer tel:07119963418
(1) Chain guide mounting bolt washer tel:07119963342
(2) (optional) s54 hub spring 11367830684
(1) Valve Cover Gasket Kit - erlang http://www.ecstuning.com/BMW-E46-M3-...Kit/ES2586868/
OR
(1) OEM Valve Cover Gasket Kit -  https://www.ecstuning.com/b-genuine-...FQpMDQodjcsBxg
Labor ran me $600 with an Indy that came to
my house.
Hope that helps!
      12-08-2021, 11:47 PM   #4
HT16
HT16's Avatar
Drives: bmw m3 e92
Could you please share your contact to do the vanos .thank you
Respect your elders
      12-10-2021, 12:55 AM   #5
Beedub
OP, well done, i look forward to doing this when my time comes, cars sub 20k miles are the moment so ill look at it , at around 40k.
FYI, those wheels in silver are just money...... ive got some new wheels on order and i look at this pic and ask myself why am i spending so much when these are so perfect for this car??
merry xmas guys.
      12-27-2021, 03:31 PM   #6
vordhosbn
Drives: Z4MC
Going to further join the chorus of DMV folks interested in Dafoe's VANOS bulletproofing services if that's still on offer. Thanks very much!
