02-20-2016, 05:51 AM | #23 |
Rep 2,704
Removal and install was easy for me as I have my car up on jackstands for the winter.
I removed my front end complete so I could R&R the oil pan. Removal of 2 bolts each side and slide the lollipop( as they are called ) off. You will need a front end alignment after. I have a set of FCAB's in the classified if interested. http://www.zpost.com/forums/showthread.php?t=1214450
02-20-2016, 07:53 AM | #24 |
Rep 588
Drives: 2007 Z4M Coupe
Thanks dude. I'll find out if they fit or not. I don't know that I necessarily need to do them but I'm at close to 90k and probably wouldn't be a bad idea.
2021 m240i on order
02-20-2016, 12:21 PM | #25 |
636
Rep 3,124
You sure about that? I thought RTABs yes, but FCABs no.
02-20-2016, 01:02 PM | #26 |
Rep 2,704
Could be wrong sticky I always thought anytime suspension was touched in any way it should be checked alignment
02-20-2016, 01:26 PM | #27 |
Rep 11,667
FCABs are OK w/o alignment due to the way the lollypop mounts to the chassis. (Locating pin)
02-20-2016, 03:03 PM | #28 |
Rep 2,704
In my case the whole front end has been out so I will want/need an alignment
02-20-2016, 07:08 PM | #29 |
Rep 2,782
I ruined a set of front tires after a few thousand miles when I didn't get an alignment after FCAB replacement. I know it shouldn't have needed one. Maybe mine were so shot that the wheel was allowed to move as it wanted, and anything out of spec was transparent; then when I replaced the FCABs, it tightened up enough that the camber or toe settings wore out the tires.
02-21-2016, 02:17 AM | #30 |
Rep 11,667
Good point.
No alignment required assumes that alignment is OK to begin with.
