      04-05-2013, 07:48 PM   #1
saintex
Drives: Z4MC BSM E92 335xDrive BSM
Z4M shift lights
Hey
Does anybody know how to enable shift lights in the mss70 DME?
thanks
      04-05-2013, 08:35 PM   #2
Mirko
Mirko's Avatar
Not possible. The tuners like ESS, EPIC or Evolve are not able to do it for our DME
I asked when getting my tune.
      04-16-2013, 06:17 PM   #3
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
Shift Lights
Hey Guys,
There IS a way to get shift lights for the Z4M. I installed the shift-i set on my baby a couple weeks ago, works great! The way to do it is to wire it to the wires running to the OBD II port from the inside. I will post more info as soon as I get a couple pics.
      04-16-2013, 06:24 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The LEDs in the tach, or a separate unit?
      04-16-2013, 07:05 PM   #5
fullerra
fullerra's Avatar
14
test test  [0.00]
Shift Lights
Its the Shift-i unit from Ecliptech (www.ecliptech.com.au) it has three wires that need to be spliced, switchable power, square wave tach signal and ground.
Using the OBD II BMW pinout and BMW wiring diagram( http://www.bmw-planet.com/diagrams/release/en/index.htm) you can see that you need to splice the wires to: (there are 7 wires that come from the opposite side of the OBD II)
1 switchable power which is the green and brown wire,
2 rpm/tach signal which is the black wire and
3 ground which is the brown wire.
It sounds more difficult than is actually was. the real PITA was working on my back in the foot well connecting the wires up.
Hopefully the two pictures I uploaded came through.
      04-16-2013, 07:10 PM   #6
fullerra
fullerra's Avatar
14
test test  [0.00]
Shift Lights
Its awesome at the track as you know EXACTLY where you are in the RPM range while keeping your eyes forward. I program the first light to come on around 4000rpm and the redline (when they are all flashing) at around 7400rpm
      04-16-2013, 07:37 PM   #7
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
Thanks for sharing! Nice find!
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      04-19-2013, 04:55 AM   #8
Beedub
awesome info!!! well done!!
      04-23-2013, 10:03 PM   #9
seank
enthusiast
seank's Avatar
48
What does 4000 rpm's do for you?
      04-24-2013, 02:41 PM   #10
txz4
txz4's Avatar
59
Drives: 2006 M coupe
Like in F1 how the lights on the dash dont even start to come on until they get like halfway up the revs.
      04-24-2013, 03:46 PM   #11
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
You have to code your ECU for European ECU, something of that nature.
My friend has it done on his E46M and it works.
      04-25-2013, 05:40 PM   #12
fullerra
fullerra's Avatar
14
test test  [0.00]
Shift Lights
4000rpm was somewhat arbitrary, but for track driving you typically like to stay much higher in the powerband of your particular engine. (all you need to do is drive down the hwy in 4th gear to see how much more power, and hence better acceleration you get higher in the rev band)
If I'm on track and I don't see any lights on, then I know that I am too high of a gear. More Importantly though, I like to know how many revs I have left before I have to shift, as it can be difficult to "hear" where you are with both with the driver side window down, and with a helmet on. Looking down at the tach would be great but for example at 120mph on a front straight means that you are covering 176 ft/sec, and a lot can happen in 176 ft.
As for programming the ECU, you may have to with other units, but this one you don't. There are two buttons on the front that you push to calibrate/program it for your application. It honestly took about 5 min or so, after I had all the wiring done to get it working properly.
      04-28-2013, 03:24 PM   #13
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
i like this, nicely done
      04-30-2013, 12:00 PM   #14
F360C
Drives: E86 S54
My set up. The same as Fullerra except I went for the curved unit.
07 Z4 M Coupe AW/IR
      04-30-2013, 12:40 PM   #15
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
Waiiiit a second. This is awesome sauce
'07 MCoupe
lots of mods
      05-09-2013, 09:02 PM   #16
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
anyone have videos of theirs in action?
      05-10-2013, 05:39 PM   #17
F360C
Drives: E86 S54
I will try and get you a video tonight
07 Z4 M Coupe AW/IR
      06-13-2013, 12:54 PM   #18
intoflatlines
      06-13-2013, 11:29 PM   #19
StickMon
StickMon's Avatar
Drives: 2006 MR
I really like that setup, it looks OEM, but I have one problem with it.
Is that really your perspective sitting in the car?
Given my height, seat position, and where I like the steering wheel (in my lap), I would have no view of that area of the dash.
I can't see the important parts of my speedo (40-80 mph) or tach (4500-7500 rpm), or my turn signal indicators.
I very tempted to saw off the top third of my steering wheel.
      06-15-2013, 09:49 AM   #20
F360C
Drives: E86 S54
I am 6'2" and with a proper performance driving steering wheel position I am able to see all of the lights. I do have Recaros though so my seats sit pretty low. Why do you keep your steering wheel so low?
At first I had the lights coming on from 5k-7800 but I have now changed and have them on coming on from 7k-7850rpm
07 Z4 M Coupe AW/IR
