      09-30-2013, 04:25 PM   #1
Swanicyouth
Drives: Z4M
TWS Oil Question
I always do my own oil changes in my E85M. I just went to buy the oil and it's the label it is now different.
Both say they are recorded by BMW for M engines, both have BMW part #s.
My main question is, can I mix them?
Thanks!
      09-30-2013, 04:35 PM   #2
Swanicyouth
Drives: Z4M
By the way, both these oils say "TWS" just in different spots in the label.
      09-30-2013, 04:43 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
It's the same on the inside.
Marketing changed the labels.
      09-30-2013, 04:55 PM   #4
Swanicyouth
Drives: Z4M
Thanks for your help. This helps because I was hoping to mix my old stock with new.
      09-30-2013, 07:51 PM   #5
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Newer stuff has a different additive package with more moly and titanium to help with wear. I did an oil sample after my lead went from 8ppm to 5ppm so I'll continue to use it. It's only one data point, but it's in the right direction.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      09-30-2013, 08:57 PM   #6
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
Having not done an oil change yet, which is the newer bottle? Left or Right in the pict?
[SIGPIC][/SIGPIC]
      09-30-2013, 10:34 PM   #7
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Edge is the newer bottle. Even the newer Edge TWS has been changed a couple of times. I have an older bottle with an SM API rating. The latest should have an SN API rating.
