      08-04-2013, 05:52 PM   #1
Krypptic
Drives: E92M, GT3
18" forged track wheel
I'm tempted to to make the leap to forged wheels for the track and have some questions. I am currently running avant garde 19" with 8.5 et35 up front and 9.5 et 22 in the rear. No rub on h&r springs with PSS 245/35 and 265/30 tires.
Is it worth going to a square setup?
8 months ago I put a brand new set of tires on the car and for the first time, on a rear drive car, I needed to change the fronts before the rears. The tread on the outside of tire began to tear away. I was told this happened due to high temps and understeer (coming into corners too fast). So if I had a square set I would have been able to rotate the tires but I was concerned about going too narrow out back or rubbing up front.
Forged Volks or Apex?
Is the added cost worth the weight saving, I'm not sure. Advan's are pricey and most aren't even forged. Are there any other cheaper forged options?
I was told three piece are not ideal for the track vs. one piece, something about the barrel and the back part the rim put together with sealant so they don't hold as wheel. Any reasons not to go three piece?
As a side not, I plan to switch to r comps for my track set, if that comes into play in the above, let me know.
Thanks for any input.
      08-04-2013, 06:43 PM   #2
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Three piece seem to be a bit heavier too.
      08-04-2013, 07:44 PM   #3
Krypptic
Drives: E92M, GT3
So they are more for show than go.
Any thoughts on forged track wheel that is not Volk or Advan?
      08-04-2013, 07:57 PM   #4
seank
enthusiast
seank's Avatar
48
For the price you can't beat Apex. Good guys too.
      08-04-2013, 08:44 PM   #5
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
^ This. Lightweight, strong, and should you do a bit of "off roading", not super expensive to replace. I'd leave the super expensive wheels for street/show or race teams that can afford them. Apex guys are great to work with too.
      08-08-2013, 03:50 AM   #6
lsz4
Drives: Z4 6.0
I have a set of 18x11 apex EC-7's same size all round for the exact reason you stated the quality of the rims are OK mine came with lots of blemishes and one was 200gm out of balance but value for money is good.
I am how ever going to get a second set of lightweight forged rims as the apex are still quite heavy with tyres mounted. I'm thinking rotiform blq concave forged.
But the guys from apex were good to deal with and had no problem shipping to Australia I would defiantly buy from them again
      08-08-2013, 07:56 PM   #7
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
VOLKS!
      08-08-2013, 10:32 PM   #8
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Volks. they come up fairly often on the m3 for sale sections
18x9 only 16.5lbs. beat that
      08-08-2013, 11:02 PM   #9
Endless619
DHS
Endless619's Avatar
Drives: 2023 M4, 2020 Land Rover
16x9 only 12.0 lbs.. Done. 16.5 pounds is heavy. LMAO.
2020 Land Rover Velar Autobiography
2023 BMW M4
2016 X3
      08-08-2013, 11:37 PM   #10
seank
enthusiast
seank's Avatar
48
200 grams. Is this a typo??? You put nearly 1/2lb of weights on the wheel?
      08-09-2013, 11:56 AM   #11
ZStig
279
that won't fit over my brakes bro
      08-09-2013, 04:44 PM   #12
lsz4
Drives: Z4 6.0
No typo I'm running 295 Dunlop direzza D03gs I thought it was the tyre, took the tyre off and ran the rim it was the rim.
      08-09-2013, 05:29 PM   #13
Shipkiller
Shipkiller's Avatar
Drives: Me
What alignment settings are you running on the track?
